Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
ESTATE WASHER WASHER WILL FILL UP WITH WATER, BUT WILL NOT WASH.
  • Anonymous Sep 14, 2008
    I have a Whirlpool Ultimate Care II washer and it fills with water but then will not run. It will start to run after slamming the lid several times(maybe between 5 and 25 lid slams) to get it going after the initial fill.
  • jdannerpete Sep 14, 2008
    I have a Whirlpool Ultimate Care II washer. It will not run on its own after the initial fill. You can get it to run after the initial fill by slamming the lid several times (between 5-25 times) and then it operates normally after that.
    Genius:
  • 1,028 Answers
Ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Posted on Sep 14, 2008
yalmer
  • 549 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
  • 15 Answers
SOURCE: washer will not fill with cold water during cycle
it sounds like your mixture valve is faulty on the cold water side. that is the valve where you screw the hose ends on. it needs to be replaced you can purchase one at your local sears, be sure to take your make and model number with you
Posted on Dec 31, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
Delicate cycle fills with water but will not agitate
Timer needs cleaning on the delicate relays (points) in the delicate position. Maybe timer failure. Transmission stuck, jammed or failing in that wash mode
Sep 21, 2012 | Estate Washing Machines
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Washer won't fill w/ water on the wash cycle and rinse cycle, it will only drain and spin on the end of the cycle
Need more info to answer the problem but clean your screens in your inlet hoses might help...bye for now
Jan 28, 2011 | Estate Washing Machines
Washer won't fill up
if there is no water on the ground or over spilling then pause the machine and lift the drain hose up until you here the water stop coming out of the hose.
keep the hose up to the top of the rear control panel and restart the machine it should fill up and go in the wash cycle
May 28, 2010 | Estate TAWS850PQ
What is the volume of water if on extra heavy load does this machine hold?? thanks
On the highest water level 20-22 gals. per fill, wash, rinse, spray rinses, equal about 44 gals without a 2nd rinse option.
May 03, 2010 | Estate TAWX700JQ Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
prem mathew
