Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Dryer When I put cycle on to wash, after the wash is complete it goes straight on to drying cycle. I have read the manual over and over but I must be missing something. All I want to do is wash the clothes spin them and finish cycle then if I decide I want to dry the clothes do so myself but the machine seems to do this automatically which I don' t want. Please help I must be doing something wrong or missing the point somewhere along the line. Thanking you
  • 3 Answers
It sounds as if you have the dryer button pressed in before you start the wash! If you don't. it is likely it is stuck in or the switch is shorting out on the back. Unless you are a competent DIYer, find someone who is to check the electrical connections and test whether the switch is working correctly.
Posted on Oct 29, 2008
Clothes are still wet after last spin cylce
Most washing machines do not dry the clothes completely. Make sure that your clothes are evenly spaced & the weight is balanced to get the best spin speed. When the cycle is complete, you will need to put the clothes into a dryer or hang them up to get them completely dry.
Aug 30, 2015 | Washing Machines
LG dryer restarts after cycle
check one of the button are stuck first
Jul 22, 2013 | LG Dryers
How do I machine wash my futon cover?
You should wash your futon cover separately from other items. You need to ensure there is room in the machine for it. Avoid using detergents containing bleach. Wash the cover using the cold wash/cold rinse cycle (unless label inscription suggests otherwise). After the wash cycle is complete, you can put the cover in the dryer and tumble dry on a low-heat setting. I like to remove the cover halfway through the drying cycle to flip it to ensure that it dries evenly.
Aug 01, 2012 | Furniture
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Dryer won't dry
www.malberusa.com
61 Commercial Ave
Garden City, NY 11530
(516) 294-6660
first empty the waste container on the right buttom of your machine you have to empty that container every couple of washes.if not solved replace the heating element. the tel # above.
good luck
Hadi
Sep 24, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Cant use dryer
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Feb 17, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
How on earth do u find auto dry?
I don't know if this helps, but the washing machines I have used will only go straight from wash to dry if the wash is set to 'half load'.
Sep 02, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
137 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
