Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite washer not agitating properly
I have a Kenmore top loader model 23032100. It was purchased in 2002. It agitates fine for small loads but not large. I tried to inspect the agitator but cannot remove the upper auger.
Any instructions on how to remove auger or suggestions are welcomed. A technical repair manual would be very helpful.
Thank you!
Dave
  • kroznest Sep 14, 2008
    Thanks! Right after I postred this I figured out the 1/2" drive extension thing. I ordered the agitator replacement kit jut to be sure I fix it.
    I really appreciate the qick response and it confirmed my assessment.
  • Anonymous Mar 14, 2014
    inoperable agitator
    Genius:
  • 1,028 Answers
Pull off fabric softner dispenser ..some twist off others pull blue ring up and then dispenser up..under neath remove the cover by prying cap or pulling up on tabs..remove 7/16 bolt or on some use 1/2 in drive extension to twist out retaning bolt pull top off and replaced the agitator dogs underneath ..part#80040
Posted on Sep 14, 2008
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
How do I replace the dog agits on my kenmore Elite 23032100 washer?
The following link explains how to replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you have any questions, please let me know. I hope this helps you.
Jul 08, 2009 | Washing Machines
Agitator looks like its stiped on my kenmore elite top load washer
kenmore top loaders have two piece agitator .down inside there are 4 little plastic pieces called dawgs .top should rachet in one direct. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
I have a Kenmore Elite top loader that does not agitate after its filled with water and the lid is shut. I've tried all speeds.
I had the same problem with my Kenmoore and had to replace the agitator...ordered the part through Sears. Wasn't hard to fix, just needed to wait for the shipment.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Kenmore 24032\24036 Top Load Washer Logo
493 people viewed this question
Sal De
fordexpert
Robert Rankin
