Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Not cooling neither side is cooling. I unplug for a while and plug back in it'll cool for about 4 hours then back to warm..Thanks Henry
Replace the defrost timer about $20-30.00. One plug 2 screws. Mine was located on the bottom front behind the grill. (model HMG 24922) . Follow startup directions.
Posted on Oct 01, 2008
Admiral side by side fridge freezer gc2227cgfw - not cooling and clicking on/off noise from bottom of unit - have pulled out to investigate was very dusty and vacc'd out loads of dust - but warm in bo
Leave the unit unplugged for at least 4 hours then plug it back up, if it still clicks and doesn't cool, the compressor is likely burned out. It sounds as though it just overheated and is tripping out on overload, it should restart and run fine if it didn't get too hot. Good Luck...
Mar 21, 2014 | Admiral Refrigerators
Plug in frig starts cooling will make a thin layer of ice in trays and frig fresh food will start to cool down then cooling stops and fan is still running. Unplug wait 30 min plug back in and starts...
That problem may take a little work finding but that is no problem if you can pull away from the wall and unplug. Then remove the lower cover that covers the compressor area so you can feel the top of the compressor. Feeling the top of the compressor tells me several things like if it has been running all this time or if very hot it will tell me that the compressor has been short cycling. Compressors short cycle for a few reasons and one is the start components photo #8 and #4 in this photo here=> ASD2628HES_COMPRESSOR_Components Another reason may be the evaporator fan or the condenser fan #20 in the photo link above are not staying on or there is an airflow restriction. When the compressor runs there should be a good steady flow of warm air from below the refrigerator. That warm air is the warm conditions being removed from inside your refrigerator. The most likely reason for this is the start relay/overload or number 4 in the photo has become defective. That is this=> Relay Overload with Start Capacitor
With that part out and able to get the=> 65889-4 15uf run_capacitor
out I would carry the run capacitor to a local refrigeration dealer and ask if they would test your run capacitor for free. I will be here if you should have questions beyound what I have mentioned here today, Thanks, Sea Breeze
Jun 13, 2011 | Amana 26 cu. ft. Side-By-Side...
Not cooling
try defrosr timer or element..
Nov 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge runs good for 3 to 4 hours.then turns on but does not cool. i unpug for about an hour and then cools good for another 3 to 4 hours
Are you sure the compressor is turning back on. I would bet that you have a tecumseh compressor in your fridge and when they get hot they don't restart till they cool. The bearings in them go bad. We replace those with Embraco compressors. You unplug it and let it cool down and that is why it restarts.
Sep 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works frige dont unplug for an hour then it works .
I would suggest check the coils to make sure they are clean . Also check the fan which cools the compressor to make sure it is working . When you unplug , it gives the compressor time to cool down a bit , but after it restarts , it will get hot again and stop cooling .
Jul 06, 2009 | Refrigerators
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Stops cooling, need to unplug, plug back in and it works for a little while
if the motor runs it cant be the thermostat then it is low gas inside the system and it must be cold after 30min
May 11, 2009 | Refrigerators
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
260 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
