SOURCE: Cannot copy files to DVD disks
First of all you should have the recording tab ON. Have you tried burning using Nero instead of dragging and dropping? This may solve the problem.
However, if you prefer to drag and drop, try setting the write speed to a slower setting, even if the dvd burner has faster write capabilities.
1. I do not think it is a hardware issue.
2. You can try replacing the IDE cable, but if you can read the contents of the disk it does not suggest a communication issue between the drive and mobo.
3. I do not think that the burning software is to blame, when you drag and drop you are actually using a windows based burning software that is installed with the operating system.
4. set up your files to burn through nero, let the software do the work.
I had the same issue with my dvd burner, although slightly different error messages, solved it by using nero instead.
SOURCE: Cannot burn CDs using itunes anymore!
Go to the Device Manager. Start>Right-Click on My Computer>Properties>Hardware tab>Device Manager. Find your CD/DVD in the list of hardware and click on the "+" sign to expand it and see your brand and model of CD/DVD device. If there is a yellow! or a redX then it is either disabled are is corrupted, just right-click and update driver.. Even if it does not say anything, right click it and update driver. Sounds like your CD ROM has driver problems.
SOURCE: I have a new emachine how do I make a dvd
Ok here ya go burn a DVD in Vista:
Insert blank disc
Window automatcally comes up click "Burn Files to Disc"
Type a name for the disc
Use Live Disc Format
Click Next--takes a minute to format
After formatting a special disc burning window opens waiting for files; drag them over and your done
SOURCE: Restore back to factory setting
take any of vista disk(any copy)
boot with cd in repair option get restore click.
SOURCE: cd/dvd wont play burn or anything /emachines el1200-05w
hi there.
have you check driver of the dvd room,on control panel click,click system,click hardware,click device manager,on device maneger click cd/dvd coom,then left click your cd room,click properties check driver,if no driver update,or if you have cd installer
install the driver.have a nice day
