Question about HTC Touch Diamond Smartphone
Hard reset for a HTC Touch Diamond
Hi - can someone let me know how (and if) I can reset my Touch Diamond to factory setting and wipe all the data (contacts etc.)? I am about to pass it on to someone and I wont to hand it over in a 'clean' condition. Many thanks for your help.
  • wedders Sep 15, 2008
    Thanks - found that but I think it just gives a soft reset. However I found the combination of buttons that enables a hard reset on www.hardreset.eu/ - thanks for the assistance.
  • buyacoob Oct 06, 2008
    I installed a software to support Arabic language and now phone does not functioning well
  • 4 Answers
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
Hard reset for a HTC Touch Diamond - htc_touch_diamond_hard_reset_soft_reset_4.jpg
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Posted on Apr 03, 2009
I have an HTC Touch Diamond. It started giving me problems with my screen was offset. I had to hit the 4 to get the 1 and couln't hit my keyboard button. It was like my whole screen was lowered. Now the whole touch screen won't work. I still can the enter, home, back and answering buttons. I reset it once and it went to the align screen, it was working off and on for about 30 mins and now back frozen. Help
Posted on Aug 30, 2009
Take back cover off and there is a reset button
Posted on Sep 15, 2008
TouchFLO is not launching in my HTC touch viva phone
Not quite sure whether the actual system is corrupted but you may try to hard reset the phone. But note that hard reset will wipe all your data so take a backup before resetting it.
Feb 18, 2011 | HTC Touch Diamond Smartphone
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
Htc touch diamond no longer connects to the internet
All you need to do is to check your packet data conmnection.
Sep 29, 2009 | HTC Touch Diamond Smartphone
Htc diamond screen is locked and forgot code how can i unlock it
If you forget your password, you can hard reset or clear the device
memory. Before you do this, make sure you back up your data and files
so that you can restore them back to your device. For more information
about hard resetting the device and clearing the memory, see “Resetting
Your Device” in this chapter. See page 244
http://x.msmobiles.com/portal/images/htc/HTC-Touch-Diamond-User-Manual.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | HTC Touch Diamond Smartphone
I'm locked out of my phone, I forgot my password and there is no way for me to get my numbers or anything out. What should I do?
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see a message on the screen for the confirmation
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 08, 2009 | HTC Touch Diamond Smartphone
Program page not working in Windows Mobile on HTC Diamond
pls rate me FIXYA
Jan 27, 2009 | HTC Touch Diamond Smartphone
Password locked on htc touch diamond
Do a hard reset. Press and hold volume down and center button and then press the red reset button behind the stylus. Cntinue holding the volume down and center button until the screen apperas with some message. Press vol up key now and let the device reset to the original factory settings..
N.B All your data and 3rd party apps will be lost
Oct 20, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
I find certain voodoo rituals to do the trick. Especially those derived from rites originating in the southern gulf coast region. To start, build a low, hot burning fire pit surrounded by granitic stones roughly the size of oranges. Be sure you have a light bed of gravel beneath the fire itself to allow air space for the spirits to commune before entering the fire and your device. Use eucalyptus logs ages approximately 2 months for the fire itself, and sprinkle a solution of pulverized bat wings soaked in winter menstrual blood from a one year old goat. Wave your Diamond over the fire vigorously while chanting the names of all three major thorn gods repeatedly. That should do the trick.
Oct 20, 2008 | HTC Touch P3450 Smartphone
Hard reset for a HTC TyTn
There are two ways:
1.
Press and hold the two soft keys (the ones with dashes on) and at the same time insert the stylus in the soft reset hole. All three things need to be done together and a warning will appear. (it is a bit fiddly)
Go to Start>Settings>System (Tab)>Clear Storage (Icon)
Mike
Sep 14, 2008 | HTC TyTN Smartphone
HTC Touch Diamond Smartphone Logo
987 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
