2001 Pontiac Aztek Logo
Posted on Sep 14, 2008
2002 Pontiac Aztec
I was driving down the road and all of a sudden the fuel gage went up to the full mark when I only had 1/4 tank. How do you fix this problem
  • 1 more comment
  • Anonymous Sep 27, 2008
    I'm having the same problem... for a week now.
    Anybody know why???
  • Anonymous Oct 10, 2008
    I have the same problem after I ran out of gas one time. And it does it all of the time. Not sure what the remidy is.
  • Anonymous Oct 16, 2008
    Same problem all gages gone crazy - temp alll the way to left - leaning on gas hand - gas hand working one minute next minute not - the speedometer is the same way - works ok then goes crazy HELP
A
Anonymous
I have also had this happen to me, but luckily it only happened once as I was driving through town, it would go to Empty to full and back to empty again...but it has never done it again.
2helpful
1helpful
I have a pontiac 2002 aztec and the fuel gauge goes up and down no matter how much gas is n it.
Replace your fuel sending unit, This is located in your fuel tank. And tell your cars computer how much fuel you have, You will most likely have to drop your fuel tank. Best of luck to you.
Gas gage goes from 1/4 tank to past full when driving down the road. How do I fix this
This sounds like a grounded wire, look at all wires under the vehicle going to the fuel tank.
2helpful
2answers
@[email protected] have 2002 pontiac montana mini-van...i filled up the tank above the full mark...got in ...started it up...it went up to full...then dropped down to empty and low fuel light stays...
It sounds like the fuel tank sending unit is bad. You can try pouring a can of BGK44 into the tank to see if it will clean up some of the deposits that can actually foul the sending unit. If that doesn't work the unit will have to be replaced.
1helpful
I have a 2002 grand prix gt my gas gage goes from full to emty sometimes it goes 3/4 sometimes 1/4 do u no what the problem is
sounds like you need new fuel pump. fuel pump located in gas tank. before you go buy a new fuel pump first push up and down on trunk of car real hard to try to dislodge the little armature inside of tank. this little armature is what sends the signal to the gauge telling you the quantity. push up and down on truck to try to dislodge small signal armature then check your quantity. try this when you are having the problem and i am willing to bet the little armature is stuck. the only way to fix is to buy a new pump.
1helpful
3answers
2005 Buick Rendezvous Fuel Gauge
well the gage is made of rubber it could be sticking no other way than to replace the gage itself/ please rate my response thank you very much
Fuel gage wont read past 1/2 mark when using fuel
it is the pontimeter in the fuel sender you can buy it seperate from the whole assembly and they had alot of problems with them please rate -jeff
2helpful
2answers
Gas gauge 2002 montana
you need a replacement fuel tank sending unit, the resistor part of the unit is faulty.. good luck!
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
