Wharfedale DTR i have bought a Wharfedale TU160DTR and for some reason when i do a channel scan to set it up it says ''scan failed'' and i only have about 15 channels? its not a reception problem because my other box (i bought this new one because i wanted a card slot) works perfectly receiving all channels. i have a setanta card and am supposed to leave it on channel 5 or channel 34(setanta) to activate my card, but i cant get those channels? i have tried everything, turning it off, resetting, unplugging the aeriel lead etc. i even changed the box as i thought it may be faulty, but that does the same thing?? please help!!!!!! thanks
I've just bought the same dtr myself, and it had no problems scanning the channels, the other solution is to register a topuptv card that you had supplied with the box, put it in the box with the pin side facing up on channel 5 for an hour, take the card out then re-insert it the same way then after upto four hours setanta should appear, aswell as the other channels, they work perfectly on mine, much better than the thomson ones ever did, le us know how you get on with it
Posted on Oct 19, 2008
How do I auto scan my youview box
You must have it connected to an aerial which receives digital signals into the aerial socket at rear.then go into the menu of the youviewbox and auto scan for all the channels it can pick up.i assume your aerial is pointing in the right direction.you can get a rough idea by looking at any aerials on neighbouring houses.once it completes the scan you must save or store those channels before exiting the menu.then the epg ( electronic program guide )will update and you should be able to select any program using the remote.i also assume the box is a working model and not been corrupted by a failed firmware update or damaged in anyway to any rear connectors.these boxes are very simple to set up so if you do get stuck you can try using the free fone number for talktalk.
Apr 24, 2015 | Humax Dtr-T1000 Youview Digital Tv...
Wharfedale tu160dtr
run a sceen on the hard drive to se if it bad
Nov 19, 2013 | Televison & Video
Wharfedale dv832b software upgrade? I bought this a ouple of years ago and sinc then it has never updated itself eve though it is enabled. I have waited and nothing haseer happened. A couple of weeks ago I...
Hello
Just get into the Wharfedale site and upgrade it with latest software available, that suit to your DVD-M3. It will take some time, say about an Hour to complete the donload and installation. Don't stop as download stops, the softwre must be installed, and it will happen only after the full download. After sucessfull download, the set will propt you that has done sucessfully. Till then, never switch off the net connection, or do nothing at set end. If installation is not successful, the fault you describe here will occur. OK.
Sep 25, 2011 | Wharfedale DVD-M3 DVD Player
The recorder won't respond to the remote and I can't change channels or access anything with remote. Mislaid the instructions which give details to fix this. Wharfedale TU160DTR Here's hoping someone can...
Try this. Open up your pc cam then point the remote straight at the cam. You should see pulsating light on the computer screen as you look at the cams video. This tells you ar least that the remote is working fine.
Jul 03, 2010 | Televison & Video
User Manual Wharfedale TU160DTR
go to
http://www.sharpelectronics.info/Manuals.aspx
select TUR160HA and click search
this is not exact model, but similar in most functions
Sep 11, 2009 | Televison & Video
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
Wharfedale DVDRHD400
where can i get a remote for the wharfdale dvdr hd400
Jan 15, 2008 | Wharfedale DVD-M3 DVD Player
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
Dec 21, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
324 people viewed this question
Top Televison & Video Experts
Electro Med Services...
