Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Code 070074054537 for xerox c2424
I'm getting a code of 070074054537 while it was cleaning
    President:
  • 2,072 Answers
Has a bad maitenance kit drive clutch.
Posted on Sep 15, 2008
How to fix disk error code 19.1 for xerox c2424
check to see if it needs to be cleaned the lazer eye could be dirty in your xrox.
Jan 31, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Tip
Disconnecting the Xerox c2424 Document Scanner
The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
(1) Perform a standard shutdown on the printer.
(2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
(3) Power up the printer.
(4) It should work. However...
If for some reason the printer won't copy, then just do what I did in my experimentation:
(2) Disconnect the Document Feeder from the printer in the rear of the printer.
(3) Physically remove the Document Feeder, leaving the copy platen visible.
(4) Power up the printer.
At this point you should be able to copy stuff.
(5) Physically reattach the Document Feeder, but DON'T reconnect it!
You should still be able to copy, scan, etc.
on Apr 16, 2010 | Xerox C2424 Copier
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
White lines will not go away in our Xerox C2424
Since you have done all that. That tells me you almost certainly have a bad print head.
They will clog or sometimes the jets get damages and it becomes impossible to pass ink through them.
I would say a bad print head is about a 99 percent probability.
May 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 system error 0701043:29778
Try some cleaning to your Printer.......
also check for any stuck in the printer
Mar 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
