Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA TV Our TV is on with a beautiful picture, but no sound? It worked fine the night before and now no sound? What could be wrong?
  • RCA Master
  • 5,138 Answers
Your SSB board is the problem its either your audio output ic or the board its self use external jacks red& white use your stereo for sound. cost of SSB board is 292.00
Posted on Sep 14, 2008
No sound
there is a switch on the back of the tv that has internal and external speakers slection i would check that especialy if you have hooked up any new componants
Dec 07, 2008 | RCA P46924 46" Rear Projection Television
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
No picture, sound ok
Rca has been known to have bad solder joints in the deflection circuits. Usually around the flyback and transformers.. check it over real good. Just be careful as you can still get shocked after the powers removed the capacitors and picture tube will hold a charge in them.
Jan 21, 2008 | RCA F36649 36" TV
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
Brand new TV and it has a beautiful picture but no sound any suggestions?
S-video does NOT carry audio.
You'll have to get some RCA audio cable and connect them to the audio in ports associated with the S-Video input.
Nov 21, 2007 | Olevia LT32HVM 32 in. LCD Television
No cable picture or sound
only thing I can think of is for you to check your cables... assuming you are using a coaxial cable for the satelite and rca cables for games and dvds, I would recommend trying a different coaxial cable. There is also the chance that the coaxial connection on the tv itself is messed up. you may try buying an RF modulator that will convert coaxial to rca, most rf modulators convert rca to coax. so make sure it does what you need before you buy it. tech guys at store should be able to help if you can't figure it out.
Jun 19, 2007 | Toshiba TP50F60/61 TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
