Question about Indesit Washing Machines
I, Just got a new washing machine about 2 weeks ago it is a indesit WIB101. The Problem Is That When The washing is finished, the next day it still has 3-4 inches of water left in the bottom of the drum
  • 958 Answers
I can not find a manual yet caused its very new. anyway, my idea is, the drain hose could have been installed so high that the water pump can not push all of the water out of the drain hose. so after the pump stops, all the water at the hose goes back to the tub and fills it up with 3-4 inches of water.
the solution is to put the hose at a level instructed in the manual . you can not leave the hose so low also that the water would just drain right away.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
    President:
  • 1,462 Answers
I bassume the water is coming in after cycle finished. source can be two things.
water valve leaking - not probable on a new machine but to check, turn water off and see if water comes in.
if drain is plumbed into a spigot on the sink trap, when you empty the sink, some of the water will go down the drain hose. to cvure, take the drain hose up in a swan neck as high as possible
My indesit model no WIB101 fills up with water but won't do anything after that
Switch for water level or hose that level switch should be clean inside...
Apr 21, 2014 | Washing Machines
WIRING FOR INDESIT WIB101
Hi where on the appliance is the wire is it a connection block can you list a photo
Mar 24, 2014 | Indesit Washing Machines
Indesit 1000 wib101 filling but programme not moving any further
once the machine has filled the next requirement is to heat to temperature on some programmes the machine will agitate on others it wont try a different programme to see if you get any motor action if you do it may be something as simple as a heater failed
Mar 04, 2014 | Washing Machines
Indesit wib101
THE COPPER CORE OF THE MAINS FLEX/CABLE IS LIKELY SNAPPED INSIDE THE INSULATION (USUALLY NEXT TO THE PLUG (IF YOU'RE LUCKY) OR NEXT TO THE MACHINE AS THESE ARE THE 2 BITS THAT MOVE/FLEX MOST). TEST THE CABLE (ALL 3 EARTH LIVE & NEUTRAL) WITH A CIRCUIT TESTER. IF BROKEN BEST TO REPLACE THE WHOLE CABLE BUT IF YOU CAN IDENTIFY THE BREAK YOU CAN CUT OFF A SECTION AND REFIT THE PLUG.
Dec 09, 2013 | Washing Machines
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
May 13, 2008 | Washing Machines
Washing machine problem
Try pressing "end of cycle" button, wait for 2 minutes before opening the door, do not force door.
Feb 04, 2008 | Washing Machines
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
232 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
