Question about Panasonic Microwave Ovens
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
  • timber85 Sep 16, 2008
    H98 code- I reset system to demo mode then reset again turning demo mode off, code H98 did not return and system is working correctly. Possible cause Voltage spike due to power outage ?
  • Panasonic Master
  • 8,862 Answers
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 16, 2008
  • William Miller
    William Miller Sep 16, 2008
    Hopefully it was a glitch, fluke or spike, etc.
    But it may be a problem that is intermittent now (like a bad connection) and will a "hard" failure with time.
    This is a standard microwave rule anyway, but especially under these circumstances be sure not to leave it unattended while it's cooking.
    If it works for a week or so, you may be okay.
Trouble code H98
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Code H98
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
May 31, 2012 | Microwave Ovens
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
May 26, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Microwave Ovens
Doesn't work
No model number?? I'd be pretty suspicious why someone removed the model / serial tag!!
I'd be even more suspicious if someone sold you a microwave with such a serious problem without informing you of it in the auction item description beforehand.
H98 means you have a bad inverter, magnetron, or control board.
You can find a troubleshooting chart for this error code here.
May 16, 2008 | Microwave Ovens
Microwave Ovens Logo
661 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
