Question about Singer Professional Sew Ware Options 2.0 (CDM556OPTIONS)
Singer Professional Sew-Ware 2.00 Converter is not compatible with my new computer that has Windows Vista
I bought a new computer and did not think about my Singer professional sew ware 2.00 being compatible. Is there an upgrade for this sullution?
  • 6 more comments
  • dihunter Oct 22, 2008
    I also have purchased a new computer with Vista and I can not get the PSW software to install.
  • nanc591 Nov 04, 2008
    Same thing, New computer vista 34 bit. software won't load
  • april134 Nov 15, 2008
    same problem
  • SAINDRA Dec 21, 2008
    MY SEW WARE IS 1.1 AND I CANT GET ANY HELP FROM SINGER OR DELL
  • Anonymous Feb 25, 2009
    i also have purchased a new computer with Vista and I can not get the PSW software to install.
  • arojoe2005 Mar 04, 2009
    While trying to install Profession Sew-Ware on Windows Vista 32 bit the program goes to 100 percent and just hangs up. If I close it all out and goto the PSW folder I can execute the program but I get a CPORTIO.Drv error. Everything works fine on Windows XP so I know my software and hardware are working fine.
  • Anonymous Apr 14, 2009
    I have a new computer without any serial ports. I bought the serial to USB converter but I still can't transfer anything fro mthe new computer to the XL-6000.
  • Djohnsond465 Apr 30, 2009
    cportio.sys error also
    New Friend:
I have a psw 2.0 and I can't down load designs from Windows 8. HELP!!!!!
Posted on Nov 27, 2012
GodBlessU
  • 3513 Answers
SOURCE: I just use my Singer
Please check the bellow link to have in-depth idea regarding your query...
http://www.singerco.com/support/faqs.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 16, 2010
SOURCE: I am trying to install my Professional Sew-Ware
The software and indeed the xl-6000 will not work with a 64bit system.I had the same problem.I bought a used laptop 32bit and windows xp and it works perfectly.You can get a serial/usb adapter to use with newer pc that doesn't have serial port,but you still need 32bit system.
Posted on Apr 03, 2010
SOURCE: Professional Sew-Ware 1.0 and 1.10
I too am having PSW 1.1 problems and tried the "COMPATABILITY MODE" solution and it did not work. 1.0 works but not when 1.1 is installed.
Posted on May 14, 2008
  • 6 Answers
SOURCE: i have a professional sew
000000
Posted on May 28, 2009
male_28_cam
  • 1555 Answers
SOURCE: I had previously used my
can you kindly let me know the version of the current driver which you are using. This problem which you are presently facing is caused due to memory error on your sewing machine. Kindly take a vaccum cleaner and blow your sewing machine off the accumalated dust. Further, You need to install the software for the USB to serial port adapter, and then plug the adapter in
and then install the software for the machine. If you don't follow the procedure you will get the error.
Posted on Sep 26, 2010
My new computer doesn't have a CD drive and it has Windows 8. :( How can I download sew ware and is it even compatible? The computer that it is on now is ancient and about to die :(
Most new PCs don't have one but you can add one for cheap. Look for a USB 2.0 External CD-ROM, portable for laptop on Amazon. Bestbuy should have them as well.
Mar 08, 2014 | Singer Professional Sew Ware Options 2.0...
I cannot get my professional sew-ware ver.2.00 converter to load on my HPg62-367DX Notebook to load in Windows 7. I have talked with Sofie and I have the Null Moden USB adapter. My messge is: Unable to...
Do you have the proper drivers for the cable? is the cable installed or does it have a little interrogation sign on it? I am sad to say that any new computer that only comes with USB ports will have a problem accepting this so called cable adapter.............It will not work ""period""
May 16, 2011 | Singer Professional Sew Ware Options 2.0...
Cannot install Singer PSW software on Windows 7
It works fine with a configuration xp compatible on windows 7.
I bought a converter serial usb in England with a chip FTI to recognize the psw 2.0
Jan 12, 2011 | Singer Professional Sew Ware Options 2.0...
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
I am trying to install the Singer professional Sew-Ware software on my new computer that us running Windows 7, I had to purchase a Serial to USB cord which I attached and installed the cord. When running...
Singer.com's FAQs provide the following:
Sep 22, 2010 | Singer Professional Sew Ware Options 2.0...
I am trying to install my Professional Sew-Ware Ver. 2.00 onto my new 64 bit computer with Windows 7. It seems that the software installs into the computer, but a message says that it cannot detect the...
Dec 15, 2009 | Singer Professional Sew Ware Options 2.0...
Singer Quantum xl-5000
Sew-ware does not come with the sewing machine. You just have the conversion tool. Professional Sew-ware 2.00 converter box is sold optional. Do a google search and you will see what I am talking about. Your sewing machine reads from a smart card that comes with the PSW 2.00 converter box. There is a cable that can connect your machine directly to your computer...Terrie
Dec 15, 2008 | Singer Quantum XL-5000 Computerized Sewing...
I bought a XL6000 from a friend and it came with Sew-Ware Conversion Tool software. I'm trying to load onto my laptop which has Windows Vista. I can't get it to come up. Do I have old software?
To either transfer/transmit from a computer to the XL6000 or for the XL6000 to recognize/read a design card: The Embroidery attachment must be attached/installed on the XL6000.
Additional information can be found at the Singer Co support site:
http://www.psw-support.com/
I found the FAQ section very helpful. (I printed it out for future reference.)
Dec 05, 2008 | Singer Professional Sew Ware Options 2.0...
Computers & Internet Logo
1,851 people viewed this question
Top Singer Computers & Internet Experts
NOEL
NOEL
Are you a Singer Computer and Internet Expert? Answer questions, earn points and help others
