I have a goodmans gcr1872 ipod alarm clock but cannot get the alarm to go off to the sound of the ipod. I select the ipod option but it defaults to buzzer every morning instead! Please help
SOURCE: buzzer instead of radio
I have this radio too and from what I have read in a review on amazon suggests alarm does not tune to DAB only FM - very annoying! Contacted Goodman customer care and they suggested it was a problem with a component but maybe it is just the design.
Posted on Apr 11, 2008
How can I find my alarm clock on my HTC inspire phone
Hi
On the Home screen,tap HTC Clock widget.
Tap on Alarms.
Select checkbox of an alarm and then that alarm.
On the set Alarm screen,use your finger to drag up or down to roll the time scroll wheels and set the alarm.
Scroll through the set Alarms screen for available options.
Choose alarm sound and also days to sound the alarm.
Select vibrate if you so wishes.
Tap on done to save the settings.
Here's a manual for your HTC smartphone.
member.america.htc.com/download/Web_materials/Manual/HTC_Inspire/110302_Ace_ATT_WWE_UM.pdf
Hope it helps.Thanks!
Feb 26, 2012 | HTC Cell Phones
Nokia 1110 alarm click default snooze to off
when an alarm appears you have two options one is snooze other is off if you select off it wont snooze......... by default snooze will come after 10 mins even if you missed it first time you can off it next time ok.
Oct 21, 2011 | Nokia 1110 Cellular Phone
How do you set aliam on my nokie e51
Got ot the link below page 67-68 will tell you how to set the alarm.
http://nds1.nokia.com/phones/files/guides/Nokia_E51_UG_en.pdf
Or
Alarm clock
Open the alarm clock tab.
To set an alarm, select Options > Set alarm. When an
alarm is active, is displayed.
To switch off the alarm, select Stop, or to stop the alarm
for 5 minutes, select Snooze. If the alarm time is reached
while the device is switched off, the device switches itself
on and starts sounding the alarm tone. If you select
Stop, the device asks whether you want to activate the
device for calls. Select No to switch off the device or Yes
to make and receive calls. Do not select Yes when wireless
phone use may cause interference or danger.
To change the alarm time, select Options > Reset
alarm.
To remove the alarm, select Options > Remove alarm.
Good luck please rate 4 thumbs up and please leave a testimonial.
Oct 28, 2010 | Cell Phones
Where can i find an online instruction manual for a goodmans gcr 1872 clock radio/i pod docking station
http://www.goodmans.co.uk/productdetails.aspx?pid=GCR1872&language=en-GB&vw=ug
then open the pdf file named "GCR1872.pdf"
hope this helps
Jan 14, 2010 | Goodmans Televison & Video
My accurian iPod Docking Alarm Clock beeps incessantly when I put my iPod on the dock. Is there any way to fix this?
The beeping is the clock telling you to progam it to find the clock page. With the iPod docked, hold the <snooze> down for a couple of seconds, it will double beep and the select prompt will move to some random page and then back to the inital menu. After the double beep, press the <snooze> which will roll the selct bar down to the "extras" menu item then select (press center circle) on the iPod twice which should be the clock. When you have got to the clock page, press and hold the <snooze> until it double beeps again.it the
If you do it right, whenever you dock your iPod, the alarm clock willl remember how to show the clock (different generations of iPods have the clock in different menu locations).
If you don't program just right, you may end up on some random page, but at least it clears up the anoying beep and it's a great charger, eh.?
Nov 11, 2009 | Audio Players & Recorders
Can't choose alarm song on iPod
The best way is to select the song you want to play is:
1: Select the song and start playing it using your iPod
2: Pause the song
3: Plug the iPod into the clock
Next time the alarm goes off it will use the song currently selected on the iPod. Hope this helps.
Mar 26, 2009 | Digital Products International Clok Smooth...
Ozaki imini (cute)
This is easy, hold down "mode" until the alarm time flashes, then press "mode" again, it will cycle through a menu, there is an "on" option to turn on the ipod at a certain time, you select "on" then press mode again, it will cycle to the next menu, set the time you want the ipod to turn on, press menu again, then you can select the "ipod off" time, I keep that option off as I want the ipod to stay on until I turn it off. Now you have set the ipod to turn on at whatever time you want. Turn off that terrible buzzer alarm. The confusing thing is the imini has to different alarm modes, not one alarm mode with two alarm sound options like most everything else.
Jan 26, 2009 | Audio Players & Recorders
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
Buzzer instead of radio
Mar 16, 2008 | Audio Players & Recorders
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
184 people viewed this question
 Grubhead
Grubhead
