Question about Microwave Ovens
Microve turns on, but will not heat Model number is FMT148G1B2
  • 2 more comments
  • sdarling83 Sep 16, 2008
    When you hit Start to cook, do the inside light and turntable come on? Yes
    Any unusual noises? No
    Is it louder or quieter than usual? No Change
  • archietpal Mar 09, 2009
    Have the same problem, not heating and humming noise when in use
  • ssgbdlc Mar 28, 2009
    Have the same problem, not heating and louder humming noise when in use. Everything else indicates it's working normally. Light comes on, table rotates, timer counts down. clock works. Went to heat water for tea on 2 minutes and after timer went off checked water and was ice cold. Tried again and noticed louder than normal humming noise from behind control panel. Tried unplugging, no change.
  • William Miller
    William Miller May 11, 2010
    Any unusual noises?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
Is it louder or quieter than usual? No change
Posted on Sep 16, 2008
Microve wILL NOT DO ANY THING COMPLETELY WENT OUT .
  1. Every microwave I've seen has a fuse in the 110 VAC line. Remove the cover or access panels and look for a ceramic or glass tube fuse with metal end caps. Replace with the same value, which is often 20 Amps.
Mar 02, 2015 | Oster OGB61101 1.1 Cubic Foot 1000-Watt...
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Model FMT148G1B2 - over range microwave will not heat food. Clock, lights, rotating plate in M/W all work, just will not heat/warm.
well that depends on the current. If the current is a fluctuating type then microwave wouldn't heat or else if high...please check..
Jul 23, 2010 | Frigidaire FMV156EM Microwave Oven
Light on the bottom of microwave wont turn on. microve not working. got error F4. what should I do?
It depends on the brand and model, but if yours is a GE, F4 is a defective humidity sensor.
Assuming the light bulb is good, if it's not coming on, chances are a surge damaged the controller when it failed.
But we can usually repair these with out $39.95 nationwide repair service.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and mention your full model number from the tag on the unit) for more information & help. We have many service manuals which you can download.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 19, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a Dawoo microve & the removable plate that spins when the oven is on needs to be replaced is this poss8ible. The number is 441CN90Do1 Thanks Gerri mgoshry@aol.com
Please visit the manufacturer web site for factory replacement parts ... of visit any of the microwave advertisers here at Fixya.com
thanks for using Fixya.com
Oct 20, 2009 | Microwave Ovens
GE Microwave Model JE1640WA runs when the door is open only
You probably have a loose or broken door switch mount or the door may be slightly misaligned.
See:
http://www.microwavedisplay.com/safety.txt
and
http://www.microwavedisplay.com/disassembly.txt
and
http://www.microwavedisplay.com/doorsw.txt
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microve turns on, but will not heat Model number is FMT148G1B2 Everything seems to work except there's no heat. Clock works, countdown timer, light, turntable, etc., just no heat.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 16, 2009 | Frigidaire FMT148G1 Microwave Oven
Microwave sedems to be working but not heating
Chances are the problem is a loose connection on the magnetron, a bad high voltage diode, or a bad diode.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 20, 2008 | Microwave Ovens
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
106 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
