Question about Apple MacBook Mac Notebook
White line on screen ??
My Macbook has a White Horizontal line running through the screen about a cm wide this comes up on boot up and only goes away When i take a screenshot can anyone help..could it be the lcd screen?
  • 1 more comment
  • millsydt Oct 02, 2008
    Yer its there all the time it disapears when i take a screenshot but its there on boot up too iv been told i need a new LCD screen is this true?
  • millsydt Oct 03, 2008
    http://www.youtube.com/watch?v=t2ueiB2ec...
    This video might help...i have done a diagnostics check on it and it didnt pick up anything im thinking of investing in a new
    Monitor because im worried i will have to get a new screen my warranty has also run out :(
  • Paul Burrows
    Paul Burrows May 11, 2010
    Hi
    is the white line there all the time and goes away when you do a screen grab? or is it only there on start up?
    Scholar:
  • 38 Answers
Being a whole vertical row of pixels, I'm afraid it does sound like dead pixels on the LCD.
Before splashing out on a new LCD it would be worth re-seating the connection to the screen. The cable goes up through the hinge so wIth the constant opening and closing the cable can get moved or pinched. I have seen that in the past. Normally that would effect the whole display but it's worth a look at.
Have you had a mac techie look at it? They would check for that before charging you for a new LCD.
You can save some money by picking up spares on ebay. Just depends on if you are confident enough to fit it yourself. As it is not that easy!
Sorry I cannot be of more help.
Posted on Oct 02, 2008
  • Paul Burrows
    Paul Burrows Oct 06, 2008
    Thanks for the doing the movie. Yep, the problem is what I thought. The only way to fix that one is replace the screen. Shame you are out of warranty, always happens just as you go out of warranty!
    I have a machine with the same problem. I just got an external monitor. They are quite cheap now so it is a could solution if you don't mind the mac being confined to your desk. Just get a nice big monitor!
    You can always look out on ebay for a 'mac for spares' some people sell theirs when the logic board or such goes (that is exspensive to fix and in most cases not worth replacing) The screen is quite easy to replace if it is still inside the lid.
    Good luck.
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
InstallatIon of Mac OS X 10.4.10
White screen issues on your Macbook are more often than not, an indication that you may have a connected peripheral or device which may be hindering your Macbook's normal start up function
What you need to do first, is remove all peripherals from (printers, scanners, USB drives etc.) and then reboot your Macbook.
If your Macbook starts up normally without a white screen, leave all the peripherals disconnected and see if you can proceed to run all of your software updates, in Apple menu>Software Updates, first, including updating to the final version of Mac OS X 10.4 Tiger, 10.4.11.
Once all of your updates are completed, then you will need to go through a process of elimination by connecting one peripheral at a time, then properly shutting down and restarting your Macbook with each device, to see if your Macbook goes to a White screen.
Depending on the number of peripherals you have normally connected to your Macbook, this may seem a little tedious at first. But considering how bothersome a White screen is, it will be worth it solving the mystery of which peripheral is causing the white screen and failure to boot up normally.
If it turns out that one of the devices you had connected was in fact, causing the white screen, this will be the opportunity for to research online, visiting the affected device's manufacturer's website or even use Google, to confirm if there are any known issues and/or updates available to address that issue.
There are other variables which can come into view with a white screen issue, but this is a good way to start in terms of working toward a viable solution to this issue with your Macbook.
I hope this helps, let me know if you have more questions.
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
Jan 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
ken@ikenfixit.com
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
Vertical Panels on the screen
If it goes away after a reboot it is very likely a video driver or video software layer problem. If it only does it coming off screen saver mode, sounds like your screen saver has become corrupt - try another or reinstall the one you are using. Otherwise, try to reinstall new drivers for the video card, and update the to latest version of DirectX.
Good luck...
Nov 06, 2007 | HP Pavilion dv1000 Notebook
Apple MacBook Mac Notebook Logo
505 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
