Question about Motorola Mobility RAZR V3
Volume button sticks on Razr V3
Recently the volume button on my phone as been continually chirping as if someone is holding down the UP button. Twice wiggling it has stopped it, but it starts again when the phone is closed. Recently I had to remove the battery to get it to stop, but it started again when the battery was reinserted. Any ideas? Thanks - SC
    Brigadier General:
  • 7,752 Answers
The phone needs to have a keypad flex reflash in the phone to correct this issue, so you will need to take the phone to a mobile service center and ahve them do it for you or try modmymoto.com.
Posted on Sep 24, 2008
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Oct 30, 2017 | Verizon Cell Phones
I cant figure out how to open my razr to check the battery...
For Razr v3 Push button on back side to open batter compartments.
For RAZR XT912/XT910. Press and hold volume down and power button to force reboot.
Mark
Motorola Support
Apr 09, 2014 | Motorola Mobility RAZR V3
I have a razr v3 cell phone. How do I turn off
hold the hang-up button down for about 3 seconds to turn phone off and on
Jul 17, 2009 | Motorola Mobility RAZR V3
Turn razr v3 phone volume down quietly
Put your finger over the speaker hole on the back. It's most likely the way you hold it.
Jun 04, 2009 | Motorola Mobility RAZR V3
Red Motorola V3 Razr
try going to settings, audio, then change the "Style". Also check the detail of it to make sure it is set for the volume and ringtone you want.
Jun 27, 2008 | Motorola Mobility RAZR V3
BUTTON ON THE OUTSIDE TO TURN THE VOLUME DOWN
try a full facroty master reset, if still persists,
take it to someone who knows how to 'flash' it
Mar 12, 2008 | Motorola Mobility RAZR V3
Motorole v3
the best solution to your prob.
is to master clear your phone and master reset,
Feb 23, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 keypad....!!!
This is usually caused by one button being stuck down, and the volume control buttons on the left of the main display, and the voice button on the right of the main display are the usual culprits. Try squeezing them and making sure they move normally. Then power down the phone, pop out the battery, and give it another shot.
Dec 15, 2007 | Motorola Mobility RAZR V3
Ringing volume
Sounds like the side volume button is sticking.
remove the battery and get some cotton wool, dampen it with methelated spirits.( JUST DAMPEN IT ) Do not soak it!!
Then wipe down the button be sure to get in the edges .
let air dry for about 20 mins then replace battery and try it out
Nov 02, 2007 | Motorola Mobility RAZR V3
RAZR V3 Problems
First of all switch off u r phone immediately.Put out the battery.Go to any Phone service center and said them u r whole story.They better help.If u continue using phone it will become fully damaged.Even it will not going to repair after that.
Oct 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
