Question about Frigidaire GLTF2940ES Front Load Washer
GLTF2940ES buzzing sound, won´t start any cycle
I have had a frigidaire GLTF2940ES since May 07 and a few days ago, during a cycle it started making a buzzing sound. We stopped it and took some load off to see if that was the problem, but now it won't start at all. There is water in the bottom of the drum and it seems to me it cannot drain it. There was also a large amount of water on the hose. How can I reach the drain pump to check if there is something stuck there ? There is a front cover below the door but I cannot see any screws from the front, are there screws below ? Or is it held by clips ? I cannot check since I have a dryer on top of the washing machine and would need some help to get it off. Any ideas or suggestions on how to act ?
  • cangelle Sep 23, 2008
    same problem buzzes and want start a cycle. water from last wash still in drum and clothes are soaking wet.
  • robina35 Sep 29, 2008
    my frigidaire washer GLTF2940ES has the moldy smell too....the machine is two years old today....i was told that the extended warranty does not cover the rotten egg smell that it gives off while washing.....i was told to use bleach at least once a week......a new problem occured today, the machine buzzes and stops mid cycle and will not drain or spin....HELP my extended warranty has now expired.....does anyone have a solution. I also have an error message E20 what does that mean...it does not mention it in the manual
I had the same issue, it was an underwire stuck in the pump. Very easy to fix, lay the washer on it's back, remove the two screws holding the bottom cover in place. Then remove the clamp holding the hose coming from the drum into the pump. The underwire was right there.
Posted on Oct 10, 2008
  • kwoodbu Oct 10, 2008
    I had the same issue it was an underwire stuck in the pump. I fixed it myself by removing the bottom cover of the waher by laying it on its back and removing the two screws holding the cover in place. I then removed the clamp that holds the hose coming out of the drum and going into the pump. Right inside of the hose was an underwire from a bra.
That is the soulution,,,,,i had a repair man at the house and he cleaned out the pump and found a couple of underwires and some coins.....machine works fine now......thank you
Posted on Oct 01, 2008
My washer wouldn't spin, then gave me a door error then wouldn't lock. So I changed out the motor wax. Be careful opening the housing to replace that because it's got a spring in it. That didn't work. So I changed the door lock and switch assembly (which includes the wax motor). That didn't do it. So we took off the black drain boot. Note: heed the bucket warnings, that stuff stinks. We accessed it through the front panel, but my model must be a little different because we had a bunch of screws to take out, plus the top, and the door gasket and unplug some misc. part. It might have been accessable from the bottom cause theres a hole in it. Oops...
Anyway, we retrieved 75 cents mostly pennies and a bunch of hair pins. The filter basket had dropped down into the bottom of the boot and we think that is what really was what did it.
So now we're gonna work backwards and return any parts we don't need. repair clinic gives a money back guarantee.
What we learned. Start with the free stuff first even if it sounds harder. Even if your husband wants to argue with you. Even if you have ADD, Clean the stinking hoses out first! Total cost $100.53. Time spent first time 45 min. Hardest part trying to put the spring back on the door gasket (trick here is to put the spring part on last) Second time 15 minutes tops. Cleaning out the boot about an hour and one small fight.
Posted on Apr 30, 2009
Yes same here, I did it before seeing the post and forgot to write up the solution.
  • 943 Answers
Hi . thanks for the question. yes there is something in the pump . the panel has 2 screws at the bottom of front panel . remove screws . remove panel . pump is on the right . put hose on floor in a bucket to drain the water out before you disconnect the hoses from pump. as there will be water . remove. the hoses and pump. clean out the pump & try thanks the appliance doc
Washer pauses during wash
Good Morning Friend,
I understand your Frigidaire washer, model# GLTF2940ES, is pausing during the wash. There could be a miscommunication between the different boards inside your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
When i turn it on, it buzzes and doesn't start
Sounds like the control board won't allow the motor to begin the cycle. Contact a professional for an accurate diagnosis.
Sep 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Running a heavy load; stopped during rinse cycle; won't drain or spin;
There may be something stuck in the pump, did you hear a buzzing or crackling noise?
Jun 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire dryer
it sounds like the programer on the drying side has had its day
Dec 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Machine stopped in mid-cycle - Have not been able to drain water or start another cycle
Ababu, sounds like there is somethng in the pump. You are are on the right track. If the pump is buzzing sounds like you are getting power to it. Get yourself a pan or bucket ready and remove the clamps from the pump. Check to see if anything is lodged in the impeller. Clean it out and try it again. Catriver...post back
Aug 27, 2006 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
202 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
