Question about Visioneer OneTouch 5600 Flatbed Scanner
Visioneer onetouch 5600 usb scanner
Hello, i have windows xp sp2 and drivers i got from the official site of visioneer doesnt work for my scanner. i cant find another drivers. also there are no drivers for linux. what can i do? thanks
Clog2020
  • 81 Answers
SOURCE: install visioneer onetouch 5600 scanner to windows xp
Go here:
http://support.visioneer.com/products/home/EOL/5600/downloads.asp
This has instructions and drivers for XP.
Posted on Apr 13, 2008
  • 4 Answers
SOURCE: Software to makE ONETOUCH VISIONEER 5800 scanner work with WINDOWS VISTA
You can go to Visioneer.com and order the disk. It is free but the shipping is $9.99.
Posted on Sep 03, 2008
drifterK
  • 4924 Answers
SOURCE: Visioneer OneTouch 8920 won't connect
If it is a usb device and it doesn't sees it ..just change the port until it sees it ...
Another thing to do is to go to control panel and run the add new hardware wizard...You can run the driver first to be sure it is in the system and after that run the wizard ..., but in a normal way it should see the usb unknown device and try to install it auto...
if it is not a usb device ..just connect it ...go to device manager by right click on the My computer icon ...properties./hardware /device manager ....here you should see the printer in yellow color and with a ask sign meaning that its missing the driver ...If you do not see it ...just right click on computer in D manager ///and choose scan for hardware changes..it should bring it to sight ..
after that right click ..and update driver ...if the driver s not an installer just browse from the update driver wizard to the location of the folder with the driver and it will take it ...
let me know if it is anything else...BY the way ..be sure the printer it is powered and on...before trying to install it ...otherwise it will not see it ..
Have a nice day and please do not forget to rate if it was helpful...
Posted on Feb 01, 2010
  • 63 Answers
SOURCE: I cannot find a Vista sp1 driver for visioneer
Unfortunately I have checked there web site and they are only supported for xp;
http://support.visioneer.com/products/5600/downloads.asp
Posted on Feb 10, 2010
SOURCE: Visioneer OneTouch 5820 USB for windows 7
ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Posted on Jun 20, 2010
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
Sep 18, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
Doesnt get connected under windows 7
For the Visioneer OneTouch 5600 Flatbed Scanner in windows 7 go to the visioneer web site at http://support.visioneer.com/products/5600/downloads.asp and download the file 5600.303110.EN.exe. Then right click on the file name and select Trouble shoot compatibility. Do not connect the scanner until told to. Run the program using the recommend settings. That installs the drivers. It does not install the paperport support software but does install the monitor in the task bar. That is enough to use the scanner and save or print the scans.
Sep 08, 2010 | Visioneer OneTouch 5600 Flatbed Scanner
Need drivers for windows xp pro 64
The XP driver is available at:
http://support.visioneer.com/products/8700/downloads.asp
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
Mar 25, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
Hi, i have a problem with my scanner visioneer one touch 5300 usb scanner i have windows xp installed on my pc and i can't find the drivers for xp of the scanner where can i find the drivers and download...
I have a GOOD, WORKING driver for the Visioneer 5300 USB scanner, for Windows XP and Vista.
I include very detailed install instructions that I have personally wrote and tested. Send me an e-mail to artb126@yahoo.com. Subject Line - 5300 USB driver
Dec 04, 2008 | Visioneer OneTouch 5300 Flatbed Scanner
Lost installation cd for visioneer 7600 scanner usb one touch
Hi! I have the correct driver for the Visioner 5300 / 7600 that will work with Windows XP and Vista. I can provide you a copy with complete instructions for installation. Please e-mail me at: artb126@yahoo.com. Subj: 7600 driver.
Oct 14, 2008 | Visioneer One Touch 7600 USB
Hi ! I have a GOOD, Working driver for the Visioneer 5300 USB scanner, to work with Windows XP and Vista. I also include detailed install instructions. Send me an e-mail to artb126@yahoo.com . Put in Subject Line - 5300 USB driver.
Apr 24, 2008 | Visioneer OneTouch 5300 Flatbed Scanner
Install visioneer onetouch 5600 scanner to windows xp
Go here:
Apr 11, 2008 | Office Equipment & Supplies
Windows X-P
Here is the link of HOW TO:
http://www.visioneer-europe.com/support/faqs/15.htm
Dec 29, 2007 | Visioneer OneTouch 7600 Flatbed Scanner
Visioneer OneTouch 5600 Flatbed Scanner Logo
610 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
