Question about Roper REX3614KW Electric Dryer
Roper Dryer heats for 5 minutes then stops heating but still tumbles. I haven't a manual so there isn't a schematic to work with. Appreciate any suggestions;
  • illdixie Nov 25, 2008
    I have a roper that heats and runs for about 5 minutes and stops. I assume there is a problem with the thing reaching max temperature and a sensor is shutting the dryer off, but I'm not sure....would appreciate any info on this. I can check thermostats with a multimeter I have but would like to have a direction before I begin taking this thing apart....It's in a small space and its a royal pain to work back there...thank you
Thanks for the reply........I figured out the problem........the type of vent hose I bought was metal flex.......(I hate those things.....when you start to install them if you're not careful they start undwiding and come apart before you can get them properly installed).....anyway, someone had pushed the dryer a little too hard up agains the wall and smashed part of the vent hose.....and that dent was enough to pinch the exhaust off, and consequently the overheat element would shut the dryer down.......unkink the hose, clear the exhaust, and back in business.......
illdixie
Posted on Dec 12, 2008
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
Roper dryer RAS7133RQ1 won't start
For starters, a user manual for your dryer can be found here.
Jun 02, 2008 | Dryers
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Dryer heats, then quits
The thermostat that controls the heat has failed. Try one of the other settings on the timer switch ans see if it will heat, the different cycles use different thermostats.
Jul 01, 2009 | Frigidaire FGQ332ES Gas Dryer
My gas dryer stopped heating
I need your serie and model #
please
May 08, 2009 | Roper RGX4634KQ Gas Dryer
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need.http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Roper REX3614KW Electric Dryer Logo
110 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
