Question about Logitech QuickCam for Notebooks Pro Personal Web Camera
Green Screen with new Logitech QuickCam Deluxe Notebook
Hello Fixya!
My friends keep getting a green screen when we try to have a video conversation using Skype, and I know it is the new camera. Are there some settings I have to adjust to make this work? somewhat suprising for a new camera! THANKS for the assistance!
-Terrence Dudley
tldudley@hotmail.com
  • tldudley Sep 14, 2008
    Solved it myself, and I'm certain there are other people experiencing the same, so I've come back to report. It turns out that my previous logitech notebook camera one day just stopped working and gave the strange green (sometimes black) screen. After numerous troubleshooting attempts, I bought a new camera (this Logitech Quickcam Deluxe) and had the EXACT same results. So, figured it was a problem not with the camera, but with the computer. After going to Control Panel/Scanners and Cameras and running the camera test there again where it said the camera was operating fine, I simply deduced that it HAD to be a problem internal to Skype. I simply downloaded the newest version of Skype, and it worked just fine. So, if you're having problems, ensure you have the latest version of Skype. Even if already, it might not be bad to re-download it once just to "re-set" it so it works with the already installed camera.
    Still does not explain WHY it wasn't working previously...but what the heck. Good luck.
IrishDruid
  • 2712 Answers
SOURCE: Image stay still on screen
No, its not a Skype issue. You may just need to download the correct software for your Logitech camera. You can download it HERE.
Next do a clean install..This is different from a regular install. Please follow the procedure carefully.
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
SOURCE: mic trouble
I have installed software, web Cam works fine.
Down loaded SKYPE ,but when speaking with another person ,I could see them and hear them OK, but they were unable to see me although sound communication was fine. Is this a web cam setting problem or Skype problem.
Posted on Oct 15, 2008
yooperbud
  • 8637 Answers
SOURCE: we can't get our quickcam 9000 to send images over skype or gmail
This should help you setup
Normal 0 Web Camera’s have to be setup on the program they areto be used with. Just installing thecamera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see andtalk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger setit up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
  • 11 Answers
SOURCE: My picture turns to "Green Screen" while video calling on Skype..
sometimes i get similar effects when i use skype or MSN my view goes yellow i think it is due to the age of the model of the webcam, so i recommend getting a better one. If the problem persists then maybe the graphics arent that good with the webcam or the software is dodgy. hope i helped!
Posted on Apr 30, 2009
  • 97 Answers
SOURCE: Have Windows XP and a Logitech QuickCam Deluxe and
make sure there is no other opened programs that could use the webcam
Posted on Aug 02, 2009
Hello there, I need driver for my logitech webcam, precision lens F 2.4 Can you please help. would be really great.
Hello there, I need driver for my logitech Problem with the Logitech QuickCam Personal Web Camera for Notebooks Deluxe
Sep 12, 2010 | Logitech QuickCam for Notebooks Deluxe
Green screen while using skype
Welcome to FixYa,
Dear User,
Please look at Skype / Tools / Options / Video Settings / Webcam Settings, and see if there is a box for "Low Light Boost". If there is, and it is checked, un-check it and try your video call again....
Still Same Uninstall Cam Driver
Download Driver From Here[select your OS and Download]
Install Driver
Still Same Let me Know Which is your Skype Version...?
Thanks for Contacting FixYA...
Jul 04, 2010 | Logitech Webcam
How to download logitech quickcam for noteboooks Deluxe through internet?
somewhere on the cam there is a model number. easiest way is to google logitech then the model number and navigate your way to their support section. If your still having trouble let me know what the model number is and we'll get you squared away
Jan 29, 2010 | Logitech Webcam
Logitech Quickcam stuck in full screen mode
just right click on the camera screen you will get the diffrent option and aplay on of them.
Sep 09, 2009 | Logitech QuickCam Communicate Deluxe...
I have a logitech Quickcam communicate Deluxe camera installed on windows XP laptop. The video defaults to Full Screen mode and I am unable to change it. I cannot even go to other screens without closing...
If you havent already I would go to Logitech's website and find the newest software for this camera, or you could try to just uninstall the software, reboot your PC and then try to reinstall.
Apr 30, 2009 | Logitech Webcam
Quickcam deluxe for notebooks logitech
you'll need to select that camera in the video settings
Feb 21, 2008 | Logitech QuickCam for Notebooks Pro...
My friend is stuck!
hmmm..it's usually a 'can the o/s see the cam' issue. He may need to reload it and install software again..happens sometimes.
Feb 19, 2008 | Logitech QuickCam for Notebooks Pro...
Blue screen instead of cam image
uninstall then reinstall then set anything to default
Jan 08, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam for Notebooks Pro Personal Web Camera Logo
59 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
