Question about Ricoh Aficio AP3800C Laser Printer
Nor printing magenta
Hi there, AP3800C is not printing magenta no matter what i do. We moved the printer recently but didnt seem to do any damage. Any suggestions as to what it might be. There is definitely toner in the cartrige.
  • 3 more comments
  • fanatic278 Sep 14, 2008
    Wiked ill try tomorrow! Thanks a lot.
    Great service!!! Ill mention this to a company i work for.
    OK, the delivery seems fine because there is devintely lots more toner in the (long unit that slides into the printer), the one that gathers all the toner. When i turn the roller by hand (and it gets covered in magnetized toner) then print, the first print comes out with a little bit of toner ont eh nedge but nothing else. Do you think there is a fault with the unit.. or maybe some sort of motor? does the same motor turn all the units?
    I got this printer from where my dad used to work and my friends and i all use it for university.
    Cheers, Stefan.
  • fanatic278 Sep 15, 2008
    Excellent, so i need to remove the clutch from the mangeta... and first swap it with one of the other colours (i imagine the clutch is screwed in somewhere at the back of the scanner (inside obviously). Then return the dev and toner units to their origional locations and print, hopefully the yellow will stop printing, and the red will start again.
    I imagine that if the red still does not work and the colour that i replace the clutch with still works then the problem will be with either the magenta toner or dev unit?
    I will be ok playing around with it, please could you send me the link to the manual to remove and swap the clutch. (I have one service manual.. not sure its in there)
    Legendary Inky! Cheers for your help, ill be in touch soon!
  • fanatic278 Sep 19, 2008
    Hi there, is the control box the circuit board at the bottom, or the bit where all the ports plug into further up? I swung the circuit board open but cant make out which the flywheels are... im imagining top left? But not too sure and dont want to upset any gears. Also, there is quite a lot of toner down here.. mostly on the metal and not over the circuit board.. i imagine i should clean this with some compressed air?
    I have not bought the service manual, will it tell me eactly how to do what youre telling me to do?
  • Ricoh Master
  • 691 Answers
If there is toner in the cart but not getting onto the page, the most likely cause is that the toner delivery tube is blocked. You can try removing the unit and vacuuming out the supply line to remove any lumps that may be lodged and then run the forced toner supply in the Service Mode.
Posted on Sep 14, 2008
  • 1 more comment
  • Inky Fingers
    Inky Fingers Sep 15, 2008
    Hi Stefan. I was getting myself lost for a minute there. The dev unit sits next to the toner unit on the 3800 and as such there is no delivery tube.
    The most likely cause for the problem is that the dev unit is not turning. This is probably NOT a motor fault, as if the motor was not turning the machine should give an SC error. Instead the system uses a motor which is constantly turning during the print process and a clutch activates to actually move drive from the spinning motor the the dev unit.
    The problem is therefor likely to be that the clutch is not operating to send drive to the dev.
    Now getting to the clutch requires a bit of bravery from the user and a reasonable amount of technical know-how. If you think you can manage to remove the clutch and find a replacement, then i can supply you a link to a service manual to help you get it fixed. You could prove the error by changing the clutch on magenta with one of the others. If that colour then fails and the magenta returns, then you know the clutch is at fault.
    Let me know how you want to proceed.
  • Inky Fingers
    To get at the clutch you need to remove the rear cover, swing the controller box out of the way, remove the drum gears with flywheels, and then you are about there. The service manual for the Ricoh AP3800C can be downloaded from
  • Inky Fingers
    Inky Fingers Sep 19, 2008
    You really should get the service manual. It will tell you exactly what part is what and how to get to the clutches etc. Clean the toner with a vacuum, not compressed air. Last thing you want is load of carcinogenic powder floating round you!!
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
Ricoh AP3800C sc389 error code
SC389 is a development gamma error in the magenta. There can be several causes for this error - a toner supply problem, incorrect toner used, a laser exposure problem etc. This is not likely to be an easy problem to fix unless you are experienced in such matters, so you may need to look for someone who can help out.
Mar 25, 2014 | Ricoh Aficio AP3800C Laser Printer
Ricoh ap3800c. I find that the printouts lack magenta. This occured after recocation of the Printer. I have changed the Dev unit and Photoconductor unit for known working ones.there was no improvement. I...
Sounds like a bad clutch for the magenta unit. You can swap the clutch with one of the others (they are the same) to verify. You haveto take the controller out and sone metal panels to get to the clutches.
Mar 06, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Printing Problem
If the marks are along the same line and look like dots the black photoconductor needs to be repalced.
Jan 21, 2009 | Ricoh Aficio AP3800C Laser Printer
Mfc 665-cw magenta clogged?
Do you use some very cheap generik ink?
If your ink wont match the specifications of the needed one clogging is the result.
If you have tried several cleaning there is unfurtunately nothing more what you can do: the ph is dead (for mag).
Mar 28, 2008 | Brother MultiFunction Center MFC-440CN...
Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
5. Check and/or replace the PSU.
SC 380 Black
motor error
SC 381 Color
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Feb 21, 2008 | Ricoh Aficio AP3800C Laser Printer
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
Toner problem
R u using gen OEM toners?
Dec 28, 2007 | Ricoh Aficio AP3800C Laser Printer
Error Message sc376
I am pretty sure Sc376 is your Magenta not Cyan. try replacing your magenta developer unit and your magenta drum unit. If you buy them from a dealer you will have to buy all the colors not just magenta. Try Ebay first and search for supplies for your model.
Oct 17, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
114 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
