Question about IBM ThinkPad T40 2373 Notebook
T40p usb 2.0 ports acting like usb 1.0
Whenever I plug a usb 2.0 compliant device into my t40p (running xp pro), i get a message that "this device can perform faster if plugged in to a usb 2.0 port" I have updated the bios, uninstalled and reinstalled the ports and hubs (and updated the drivers), installed windows xp sp3, oh, and verified that the machine does actually have usb 2 ports. Any ideas?
Thanks,
Michelle
  • 2 more comments
  • ciustagabber Nov 27, 2008
    By Ciusta,
    Sorry guys, I used my ibmt40 for 5 years and I love it, but now have a problem with my usb port, when I plug the external HD that I used for years now said: Pheripheric not reconize, but why?If yesterday worked well and now are 1 month that I can plug something only after 30 times trying.Plese don't tell me software problem, there aren't! Thanks a lot everybody!!!
  • skime123 Jan 18, 2009
    Same problem exactally - when I plug in a USB 2.0 device my IBM T40p doesn't find it and says I could be running faster if it was plugged into a USB 2.o port (which it is)!!! No splats on system setup.
    Help!!!
    Help -
    same issue...seems as if machine doesn't know it has a USB 2.0 port.
    Other site havee suggested that it is a motherboard issue and IBM is aware of it. Any ideas how to get IBM to fix/replace if machine is out of warranty?
    Thanks,
    Gds
  • doomhacker Mar 15, 2009
    Also in my thinkpad T40P usb ports run at 1.1 speed.
    HELP HELP
    someone please..
    Scholar:
  • 188 Answers
There is no hardware or software fix for this. Here is a thread on what might be your problem. http://forum.thinkpads.com/viewtopic.php?t=67571
Posted on Sep 25, 2008
I just bought an ASUS notebook but the USB cannot read any device what do i do?
Hi,Some USB devices are not APM/ACPI friendly and may not operate properly after resuming from Standby or Hibernation. Some of these steps may not apply to your computer. Test the attached USB device after performing each step.
1. Verify that a USB port and an operating system with USB support are being used to attach a USB interface external device to a ThinkPad system.
Note: The following is an example image of a ThinkPad system USB port
USB port
2. Verify that the latest BIOS and embedded controller for the ThinkPad system has been installed.
View the latest BIOS files for all ThinkPad systems(-307.ibm.com/pc/support/site.wss/BMOE-3VAM8Y.html)
3. Verify that USB is enabled in BIOS.
* For ThinkPad A, G, R, T, X and Z series systems
1. Turn on the computer.
2. While the "Press F1 for BIOS Setup Utility" or "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower left area of the screen, press the F1 key, blue Access IBM, or ThinkVantage button.
3. Select Config and then click USB. The window should list USB BIOS support as [Enabled].
For ThinkPad 600, 600E, 770, 770E/ED, 770X, and 770Z systems
1. Press and hold the F1 key and then turn on the computer. Hold the F1 key until the Easy-Setup menu appears. If a password prompt appears, type the correct password.
2. Select Config.
3. Select Initialize and then click OK.
4. Click Exit, click Restart, and then click OK to restart the system
4. Verify that the USB device and any required drivers were installed in accordance with the manufacturer's instructions.
This may require removing the USB device and the drivers, and then reinstalling the USB device and the latest drivers.
5. Verify the USB device works on another machine, if available.
6. Verify another USB device, if available, works on this machine.
7. Verify that the USB device is USB 1.1 or 2.0 compliant.
Plugging specific USB 1.1 compliant devices into a USB 2.0 compliant port will cause an error message dialog box to appear. That dialog box details that a non-high speed device has been attached to a high speed port. The device should function normally, but at a slower speed than if a 2.0 device is attached to 2.0 port. Most USB 1.1 devices will function normally in USB 2.0 ports.
8. Verify that external power is attached if required.
Some USB 2.0 devices will require additional power from external sources or an additional USB port to function correctly in USB 1.1 compliant computers.
9. Verify that the latest Microsoft Windows Service Pack has been installed for the operating system installed on the computer.
There are updates and fixes to USB 1.1 and USB 2.0 available in Service Packs.
10. If an operating system was installed from a retail CD, then refer to installing USB 2.0 support on ThinkPad systems.
11. Test the USB port for errors.
Run the PC Doctor diagnostics for all current ThinkPad systems. PC Doctor for DOS is available by pressing the F11 key or the blue Access button during startup to access the predesktop menu area. If these methods are not available for your system, then PC Doctor for DOS may be downloaded. This DOS version requires two or more floppy diskettes depending on the ThinkPad system.
12. If these steps have not solved your problem:
Refer to "Need more help?"
You could also try downloading an updated/fresh copy of the drivers for my specific model notebook from Asus's web site and just reinstall over the old ones.
And if you don't understand much about it, i would advice you take it back from where you bought it from and get a replacement if it's on guarantee...
Thanks for using fixya....
Nov 01, 2010 | Computers & Internet
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Windows XP Pro USB HID problem.
First suggestion is to shut down, change ports and then, upon reboot, wait a few minutes to let XP resolve the 'new' USB devices.
Second suggestion is to download and install the manufacturers drivers and then try switching ports.
Final suggestion is to use the port that works. i.e. I went to the doctor and said "It hurts when I do this". He replied "Well, then don't do that.".
Good luck
p.s. you may want to list the model of the keyboard if you would like a more specific response.
Sep 09, 2009 | Computers & Internet
Only 2 usb ports ever work at one time.
Are these on board or do you have a PCI card with USB cards plugge in? also is some of the devices usb 1 and some USB 2.0? let me know and I will try to help yo with the issue.
Aug 17, 2009 | ASUS P4GE-MX Motherboard
Pop up message says that I have a USB device that is not recogniz
Do you have anything like a printer or scanner or an external USB drive connected to the computer. If yes, then remove it. If not let me know.
May 14, 2009 | Toshiba Satellite 5005-S504 Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
IBM ThinkPad T40 2373 Notebook Logo
975 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
