Question about Acer Aspire 1640Z Notebook
Black screen When switched on the screen is black. The computer is used by my son and I don't think he has been fiddling with the BIOS set up or any thing. Suggestions anyone?
    Sergeant:
    Champion:
  • 256 Answers
Check ram on your laptop. 90% hardware problem not with bios....
Posted on Sep 14, 2008
Acer aspire notebook touch screen dont work when touched
You have to go into your BIOS and set it to touch screen.
Nov 15, 2014 | Acer Aspire E1-510P-29204G50Mnkk 15.6"...
Turns on but black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 04, 2013 | MSI Wind U100-030US Laptop
Black screen
Sep 16, 2013 | Dell Latitude E5500 Laptop
Black screen flash bios
First Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
second restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
IF you able to start in the safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 04, 2013 | Asrock Computers & Internet
Black screen
- First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then Update your graphic drivers for your hardware also Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing this black screen
Jul 02, 2013 | Computers & Internet
Blackscreen i think
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including Black screen
Or restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then Removing the graphics driver in safe mode might work for you. Just remove it via Device manager and update them from the manufacturer site
Benq monitor black bar
you monitor has an Auto Config button, push it. Or go into the screen menu (buttons on monitor) and find the auto setting there. If that doesn't work, check your display properties and make sure you desktop is set to the same size as you computer screen.
Apr 15, 2013 | BenQ Computers & Internet
My 5640 will not boot no signal to moniter or key board canot use recovery disc hard drive still running it was running then I got the black screen
Well, sounds like bad luck for you. No, seriously, could you have gotten a virus? We can get you out of this, but it will take a little fiddling inside your computer.
Take the skin off the system. Look for where your Hard Drive is mounted, usually above or below the Floppy drive ( if you have one ). Pull out the 4 pin DC connector going into your hard drive - it has red, Yellow, black and orange for SATA drives and red black black yellow for IDE drives. Fire up your computer and boot from CD or DVD. Go through your BIOS setup if you must.
From boot, do not say you want to reformat or anything nasty, just try to look around your bios screen for anything weird. You can plug in your SATA drive hot if you want, to see if it will spin up and show data on C: Write me back when you have done these steps.
Mar 22, 2010 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
Aug 15, 2007 | Likom Futura LD7 17" CRT Monitor
Acer Aspire 1640Z Notebook Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
