Question about Whirlpool Refrigerators
SMOKE COMING FROM BACK OF FREEZER
Smoke is coming from lower rear of unit.
    President:
  • 1,462 Answers
Smoke is probably from the start relay - often a ptfe wafer these days. reasonably cheap part and easy to fix. take cover off compressor electrics and all will be revealed
Posted on Sep 14, 2008
    Novelist:
  • 171 Answers
Hi jimali1987,
I'm Harvey the Master Plumber.
Your problem is: Smoke is coming from lower rear of unit.
Unplug! Remember where there's smoke there's fire. Get access to compressor and find the burnt wire or whatever it was. I have found burnt animal nest in the past. You never know.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Engine cylinder #2 misfire and smoke coming from rear of motor and will not start.
Well,you may have an oil leak,but #2 missfire may mean a few things.
Pull #2 spark plug and see what's up.
be sure you are getting spark to #2.
Check for a vacuum leak,also.
Oct 05, 2014 | 2002 Dodge Durango
Smoke is coming out of the a/c
Ice probably formed on the outside of the unit and the a/c is working to defrost itself. Check out this page: http://andysair.blogspot.com/2010/01/looks-like-smoke-is-coming-out-of-my.html
Jul 08, 2010 | Sharp AFS60NX Thru-Wall/Window Air...
Engine light is on smoke test revealed vacuum leak at back of eng
Vacuum boot comes off of the intake manifold at rear of engine, passenger side. Super hard to get to. you cannot see it. You have to do it by feel. After a startup backfire, mine popped off. My mechanic couldn't find it, but a smoke test of the vacuum system confirmed it was coming out between firewall, and intake. It took me @ an hour to find it. Pushed it back on and it works great.
Jan 15, 2010 | 2004 Ford F150
I have smoke coming out of the freezer fan grill and water dripping outside on each side of the shell between the freezer and refrigerator. What is the problem?
Your drain may be plugged and water is getting onto the fan's electrical.
Go to back of the unit, remove access panel, check that the little drain tube is dripping water into the evap tray. Tray should be somewhat wet. You can use pipecleaner or coathanger to check for clogs in drain. Or cut the bottom rubber piece off to allow better flow..
Nov 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
KENNMORE AIR CONDITIONER
This smoke is actually condensation formed by having a humid room meeting the cold dry air. This is not a problem and does not pose a threat. Similar to the effect when you open your fridge or more obvious your freezer. Just temperature and humidity differances causing this.
Aug 03, 2008 | Kenmore 75085 Air Conditioner
Warm Freezer and How do I set or reset the defrost mode
smoke smell coming from fridge, open back cover and a smokey cloud came out of the compressor what's going on with fridge?
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
Refrigerators Logo
196 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
