Question about Dell E151FP 15" Flat Panel LCD Monitor
Blinking Orange LED light on E151FP monitor
After having my computer and monitor off for about a week, I turned on the computer and monitor yesterday. On the monitor there is a brief flash of light, and then the screen goes blank, meanwhile the LED light flashes orange.
I have checked all connections, turned the monitor and computer off and on several times, but the problem persists.
Please advise,
Thanks,
Dave Thomas
  • 3 Answers
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Posted on Oct 19, 2008
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell Monitor 15"flat panel-2 Horiz. black lines
HAS IT HAPPEN ANYMORE OR IS STILL THERE.
CHECK YOUR DRIVERS, UPDATE THE DRIVERS, CHECK THE CONTROL PANAL IN THE FOLLOWING FOLDER DEVICE MANAGER, PROBLEMS REPORT, SYNC CENTER
OTHER THAN THAT TECHN SUPPORT OF YOUR VENDER WHERE YOU BOUGHT YOUR MONITOR FROM OR GO ON LINE AND TYPE THE FOLLOWING INFORMATION EXAMPLE:
DELL E151FP FLAT PANEL LCD MONITOR 2 BRUSH STROKES ON SCREEN
ENTER
SEE IF ANYONE ELSE MAY OF HAD THE PROBLEM OR TO COME FIND OUT THAT THAT WAS A RECALL ITEM FOR THAT MONITOR, JUST KIDDING, ITS WAY OUT THERE
ROD
Feb 09, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Computer monitor problem
ok the problem is not the monitor it is either the cable checke each end for bent pins inside or the computer you are trying to use
Jan 13, 2018 | Computers & Internet
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Blinking L.E.D. light on dell monitor
Try lowering the screen resolution to 1024x768 and see if it displays on the screen. You will need another monitor (possibly CRT as they do high resolutions) to do this.
Nov 09, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
The monitor would not turn on. Only the orange LED does.
1. Make sure the monitor cable is fully plugged into the computer. 2. If the new monitor works fine, The connection between the previous monitor and the PC was bad. Reconnect the original monitor to the PC and make sure that the connection is snug. Tighten down the video connectors until they are snug. Try again. good luck..
Jan 06, 2006 | Hitachi CM772 19 in.CRT Conventional...
Dell E151FP 15" Flat Panel LCD Monitor Logo
361 people viewed this question
Alun Cox
