Question about Cat5e 100 Foot Shielded STP 350mhz Network Cable with Boots (C5SB100GRAY)
CAT5e I want to know the maximum distance that I can run a CAT5e cable from my PABX LAN port to a computer device that is about 150- 200m away.Same premises. The computer device is mainly to do the credit management device of the users telephones on the PABX. PIETER v/d MERWE vdmerwep@telecom.na
  • Carl Navarro
    Carl Navarro May 11, 2010
    You must already know this exceeds the distance limitation of Ethernet. Now, what does a "credit management" device do?
    Ethernet over that distance is done with ethernet extenders and serial data at slower speeds will travel the 200 meters without a problem or can be extended via short haul modem.
    Problem Solver:
  • 10 Answers
The max distance that Cat5e or Cat6 can be run is 90 meters or 295 feet. As cnavarro stated, signal repeaters would be best utilized in your situation up to 590 feet otherwise fiberoptics are the next and more expensive route. You should also divide the run equally with the repeater as it would not be effective with an offset balance.
Posted on Nov 05, 2008
What network cable does a belkin N600 use RJ11or RJ12
Look again. Those "RJ11/RJ12" are not 2-pair/3-pair small Telco jacks but rather the 4-pair lager size found in Telco data com circuits (ancient DS0/T1 technology) and commonly now for Ethernet often referred as Local Area Network, LAN, data communications at 10 up to 1000 Mbps.
An RJ45 is larger and can not fit into an RJ11/RJ12 jack. The smaller RJ11/RJ11 will insert and make contact with the inner pins but if the line is active the Belkin device now has/will have a blown port. Don't!
Your Belkin N600 expects one Ethernet cable from a cable or DSL modem into the WAN or Internet port on the Belkin N600 for link through your carrier to Internet.
A four port gang of Ethernet RJ45 plugs is also present and is where your in-house PCs and Ethernet peripherals plug in. On the OEM website usually there is a colored quick setup guide to help you.
Some OEMs designate a yellow Ethernet wire from cable/DSL/satellite modem to WAN port and blue for internal LAN devices to try to reinforce outside verses after the NAT firewall inside the router for your internal LAN. The signal doesn't care about color it's for you.
The internally generated WiFi or WLAN (wireless LAN) is part of the LAN side but allows WiFi radio connection to client devices.
The 4-pair Ethernet cables have 8 conductors wIth the wire end of the plug to you and the contacts held upwards you will note the four pairs and their colors blue, orange, green and brown each with one conductor of the pair white with the color and then the color solid or more correctly the color with white stripe. Signals are on pins (left to right) 1&2, 3&6. On standard cable both ends are the same - a straight through, for hub to client. A cross-over cable takes 1&2 to 3 &6 on the opposite end and vice versa. This was for client to client or hub to hub connections before auto-sensing ports showed up to make the signals swap if needed automatically found in most equipment today. Some cables from OEMs have the correct physical size and pinouts, but only use the 2 signaling pairs. It is best to use these short distances and preferably away from rf noise like in modem to WAN port connections.
The twists per inch in the cable and interweave determines frequency response which defines CAT 3, CAT5, CAT5e and CAT6 level of Ethernet cables. CAT5 is fine else CAT5e/CAT6. CAT3 is generally considered now for telco use only, but can be pressed into into service short haul. (Won't get the 328 ft rated reliably above 10baseT speeds).
You may run across Ethernet with PoE this means on unused pairs a device like a video camera is fed power as well as data connectivity over its Ethernet connection. Follow directions to put power to the correct location as needed and look for any recommended grounding requirements, especially with antennas.
Prices vary widely depending upon bubble packaging and the store overhead generally $6-$12 for about 6 ft or 2 m.
If you want to make your own then RTFM and understand millage may vary until you get the right tools and parts and practice while adhering to standards. I find it more cost effective to use pre-made & tested cables except if failure at an end then I repair followed by testing to re-qualify the cable to not degrade its use.
OBTW - Generally the USB was for single computer use at lower speeds of earlier service speeds below 3-6 Mbps - usually don't.
Aug 27, 2012 | Belkin N600 DB Wireless Dual Band N Router
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
The scrren either says resolution is not supported (mode 1) or the screen wiggles and shakes (mode 2). A directly connected pc works fine. I am sending to a tv with pc input as the remote display
The QVS VBC5 video extender supports a maximum resolution of 1600x1200 @ 60Hz for up to 50meters (164feet) & 1024x768 @ 60Hz for up to 100meters (330feet).
Make sure your maximum distance of Category 5 cable from your source to your television is no longer than 330 feet if using a 1024x768 resolution. Try dropping the resolution on your source computer in Mode 2 to resolve the issue.
Mar 29, 2011 | QVS VBC5 VGA/RGB Video CAT5e Extender ...
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I bought 1 box of belden cat5e for LAN. when i test it with LAN tester the cables are good but when i connect it to the modem/hub it is not connecting.. please help me.. thanks..
If you've tested the cable and your not getting a link light, there is a posibility that either the port in the switch or the network card is bad.You can try moving the cable to an existing working port on the switch to see if it links up. If not then try another device like a laptop or printer with a NIC card on the cable
Sep 07, 2010 | Belden CAT5e Plenum 4Pair...
I face a problem to connect a to office with a 95mtr cat5e cable.switch is not blink on both hands.
95 meters is simply too long. No way of getting a signal on the other end without the use of a repeater. The maximum distance for CAT5e and CAT6 is 295ft, which is roughly 90 meters, but even that only works in an ideal environment. Often the max distance is announced with "300ft = 100m", but that is not true (and 300ft are only 95 meters anyways.)
The best option is fiber optic cable, but that is very expensive.
Read also this article - it has some good explanations and comments.
I would buy a cheap router (WRT54G i.e.) and modify it with some third-party firmware as repeater. That would cost you not more than 25-50$. (Tip: google "Router as Repeater", and you will find many results.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 01, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Nov 04, 2007 | Cat5e Cat 5E Modular Plugs - For Round...
Connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
Dec 08, 2006 | Kingston EtheRx Networking Switch
Cat5e 100 Foot Shielded STP 350mhz Network Cable with Boots (C5SB100GRAY) Logo
231 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
