Question about Cobra PR 260-2WXVP Two Way Radio
Cobra PR 260
I have a pair of cobra pr260 2 way radios and i get no distance out of themi go about 2 houses away. the sounde even within 20 feet of eachother is also very distorted. can anyone help me?
thanx
dave
  • 91 Answers
Dear sir,
Try to operate in channel 1~7 , keep the maximum range extender button pressed for 5 seconds u will hear 2 beeps sounds. If it works Ok or else u need to change your Radio antennae
Posted on Apr 12, 2009
HOW TO TURN ON COBRA MICROTALK PR 260 WALKIE TALKIES
you have to press & hold the "mode" button for a few seconds, same to shut them off
May 11, 2014 | Cobra Microtalk Pr260 2 Way Radios Walkie...
Tip
Cb ranges in mileage.
I have experimented for many years with various antennas and gain in the frequencies 26.965 to 27.405mhz. I have found that best performances on the Citizens Band is upper channels 37 or 39. This is where the band gets quieter and more close to Fm type communicating. Performance in antenna and hearing is best here. The Antron A99 sitting just 15 feet will get you 50 miles with decent results on a cheap Cobra 19plus or Cobra 21LTD. I can tell you by fact that a Cobra 21Ltd is equal to Cobra 25Ltd's(don't let noone tell you different) Its the same board, same calibration, same wattage plus its about $15 or so dollars cheaper than. Antennas have to be set for your frequency. I have found that the 8.5 ft(102 inch) steel whip performs best at approximate Channel #37 to 40. Homemade antennas built with a 8.25 ft element and 2 8foot rods down the side(ground) with a rod crossing the bottom at 1.5 feet. In the shape of a womans skirt.( Do not let the ground "skirt" touch the pole,seperate it by plastic PVC or milk jug with trash bag ties) I got 50 to 60 miles with this homemade job I would say had a DB gain of 10dbi. I have built home antennas that outperform Antrons. To be safe though and quick to setup is Antron A99 for about $65. Antrons have already set the frequency and low SWR. !!!DO NOT TUNE ANTRON A99 - IT BREAKS INTERNALLY!!! The average range one can get is say 10 to 50 miles average(best at night 10pm to 3 am) Don't expect any better with a Superior radio and tower or linear. A linear may kick hard within 25 miles but after that it fades into low in the distance. Unless you use 10 kilowatt or 25 Kilowatts(Electric bill will increase by $300 more--who needs it) A good power Mic on a straight radio Cobra 21LTD or 25 Ltd will be better than any mid-size linear say up to 250 watts. Your radio itself has potential with antenna gain of equal 25 to 45 watts alone. Mathematically your best with a Super Antenna and Height above 35 feet, plus heavy grounding(chain link fence buried into earth 20 X 20 feet about 8 feet down(a rod 8ft also will work) or if possible a Junk car buried into earth 8-10 feet under your Antenna. Use heavy gauge thick LOWLOSS 50 ohm coax 95% shield less than 100 feet to achieve max power out. Lengths in coax are great at 9,18,27,36 up to 72 feet(No higher than needed) The old timers swear by 72 feet. Antenna Height say: 45 feet tower with 72 feet of Coax is the usual Base setup. FCC restricts antenna towers to 60 feet above ground. No more than 20 feet above your house somewhat(when attached to house roof). No need to put $10,000 dollars in a setup with no more range than others. A mobile radio(Tuned) with Antron A99 will about outdo all Base station radios. Hope this helps you. 73's to you all.
on May 04, 2011 | Radio Communications
Hi, I have a pair of PR 385 hand helds, could anybody tell me if any other battery packs from any other model Cobra fit my radios. I,ve searched and can't find a specific pack for the 385. If you
I realize this is a bit late, but I have to comment. When I viewed this page there were two responses to the original query (one that I also have).
It is terribly painful to have had to read them because they are both so sincere in their desire to help and so clueless in their response. The original poster asked about replacement batteries for the Cobra PR385 2-way radio. Both respondents posted about a DIFFERENT model. The first I can understand the mixup, he posted about the PR3850wx, If you don't mind the extra 0wx at the end then it is all fine. The second posted about the LI 7200 wx??? What??
Please, we all want help, but check your information before you post your response. The Cobra PR385 radios use the FA_NICD battery pack at 4.8v and 300mAh.
I did just find a source for batteries if anyone is in need:http://www.tomsawyer2wayradios.com/catalog/item/3823249/4705619.htm
orhttp://www.emtcompany.com/cobra-fa-nicd-two-way-radio/fanicdx.html
I have not tried either of these shops but will be ordering shortly.
Oct 14, 2012 | Cobra Electronics microTALK® PR 3850 WX ...
How do u set up a cobra 148gtl 40 channel to here far away
hello there firstly you will need to raise your antenna has high as possible and buy a preamplifier this will raise the weak stations and give better signals hope this helps
Mar 20, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
I have lost my nstruction book for my cobra pr-150 two way radios .Where can i download it? hanks.
Hello Danny
The user manual for your PR-150 is available as a pdf download direct from Cobra:
PR-150 Manual
Nov 11, 2010 | Cobra Electronics Two Way Radio
Cobra MT800
Hello SSPD12,
To turn off the tones whch sound whenever you press a key do the following:
1. Press the MODE button until the music note icon on the display flashes.
2. Press UP or DOWN to select the desired setting (either On or Off).
3. Press MODE again to save or simply wait 15 seconds.
Hope that helps.
Ken
"Go Ahead. Use Us."
Jun 03, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Cobra two way radio
Rich,
This is a discontinued product, and at that price point, they're completely disposable. If not working properly, then toss and replace.
Cobra microTALK PR 245 Two Way Radio
Oct 14, 2017 | Cobra PR-245/2 (7 Channels) 2-Way Radio
Cobra PR 260-2WXVP  Two Way Radio Logo
170 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
