Question about Tascam DP01 All-In-One Recording Package Microphone
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project, I am unable to assign any more channels to either input A or B. The manual is no help. Here's another question: do the white assign buttons ever light up, or only just the small yellow one's next to them?
  • 4 more comments
  • FluteFiddler Sep 14, 2008
    Thanks for getting back to me so quickly, but it does not solve the problem I am having. Tracks one and two have been recorded on and saved at the end of my first session. Since then,I've reloaded the project ("song") but I've been unable to "arm" additional tracks for recording on either input A or B. Hope someone will keep trying to figure this one out. DA
    Just the sort of review that convinced me to purchase my DP-02. Unfortunately this material does nothing to solve my problem. But thanks anyways.
    That particular question is about the white rectangular assign buttons. When activated by pressing it along with the shift key, the little amber light next to it toggles on or off depending on activity or inactivity. My question about the assign buttons is whether or not they themselves lightup, and if so -- under what conditions? This is more of a curiosity since my assign buttons seem to work fine.
    But as to the main question. When I start with a newly created song, any of the tracks can successfully be "armed" to eighther the A or B input bus. The levels will show readings for the bus, the armed track, and the master. After two tracks have been recorded, it seems as though the recorder will no longer allow me to arm any of the remaining 6 tracks regardless of buss choice.
    Perhaps I should have started by saying that I have gone over the owners manual repeatedly and have not found the answer in it. If you found the answer in it, I would be grateful to have you point it out. As far as I am aware, I am doing everything correctly -- according to the manual. Again, if you spotted the answer, please cite the page and paragraph. Thanks for mentioning the manual, though. I'm sure there are some who would not look there first.
    One or both inputs A and/or B must be assigned in order to record. Is that what you meant? If so, then of course one or the other has been assigned. I've never had both on at the same time, though the manual says it can be done as long as both are not assigned to the same track.
  • FluteFiddler Sep 15, 2008
    I knew it had to be some fundamental step that I was missing. Thanks so much for spotting what surely must have seemed obvious to you, but completely overlooked by me. Great job!
  • 4,472 Answers
P.23 of the manual tells you how to do it. If you want to assign the input to another track, you must first clear the current assignment, and then re-assign the input. If you need further assistance let me know. If you have a moment to accept and rate my solution it would be greatly appreciated.
Thanks,
lee
Posted on Sep 15, 2008
  • Lee A.
    Lee A. Sep 15, 2008
    You are very welcome. Glad I could help. It wasn't necessarily obvious but It did sound like the exact answer you were looking for. Enjoy!
    Thanks,
    Lee
    Scholar:
  • 163 Answers
Owners manual may be helpful. Have a look below
http://www.tascam.com/products/dp-02;9,16,3580,19.html
Posted on Sep 14, 2008
  • 43 Answers
This is the answer to the light queston,
they should be on if you assigned the input to the input plugins beside it
  • Bill schichtl
    Bill schichtl Sep 14, 2008
    i did some research
    is a or b chanel already assigned if so your recorder doesent take multichanels
    President:
  • 1,952 Answers
Acam's DP02 makes recording simple by matching 8-track CD-quality recording with a Portastudio interface - so you can ditch the menus and concentrate on the music. A pair of record-quality Tascam mic pres feature XLR inputs with phantom power for condenser mics and a guitar in for direct recording. Each channel gives you dedicated controls for instant access to fader level, record arm/track mute, pan, effect send, high and low EQ. There's also an EQ frequency button for finer control over the mix.
Two effects processors are included in the DP02. A multieffects processor on the input provides great-sounding overdrive, flange, delay and more for your guitar, vocal, drum and bass tracks. In addition, there's a reverb processor on a send and return for adding hall, room, plate or chamber reverb to your mix. The DP02 is loaded with great Tascam extras like a chromatic tuner, metronome, and bar-and-beat display for getting around your song.
The DP02 records two channels at a time to a built-in 40GB hard drive. When you're satisfied with your production, arm the dedicated master track for your stereo mixdown. You can transfer your tracks and mixes or backup your song to a computer through a speedy USB 2.0 connection or burn it to a CD with the slot-loading drive. No other workstation makes recording so simple, affordable and fun as the Tascam DP02.
Features:
Two XLR mic/line inputs with phantom power for condenser microphones
Eight-track recording at uncompressed 44.1k/16-bit audio quality
Portastudio-based interface with volume fader, pan, effect send, high and low EQ controls per channel
EQ frequency button to access high and low EQ shelf frequencies
USB 2.0 interface for transferring tracks, mixes and backup files to a computer
Dedicated stereo master track for mixdown
Internal metronome and bar/beat display for song position
Headphone output
Stereo line outputs on RCA analog and S/PDIF optical digital connectors
40GB internal hard drive
Multieffects processor with guitar, bass, vocal and drum programs
Stereo reverb processor with send/return controls for multichannel mixing
Built-in chromatic tuner
Built-in CD-RW burner for CD mastering and song backup
    Master:
  • 726 Answers
I had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
  • chris07551 Sep 14, 2008
    it saying the same way you did the first ones it should be the same ,,
    im still looking for you but .
    it also says you cant resume and add to same channel for some reason
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Just got a Tascam DP-01 and plug my keyboard into input A and assigned it. I clicked the record button for track one . I can hear the output in the headphones and the meter is showing on the Tascam, but...
If the track can be armed for recording, it won't show anything until you arm that track. Otherwise, check to see if you can hear anything on the main output. If so, then it's just the lights, which will not affect functionality.
Hope that helps!
Feb 12, 2011 | Tascam DP01 All-In-One Recording Package...
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Nov 25, 2008 | Tascam 2488 Portastudio Multitrack...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam DP01 All-In-One Recording Package Microphone Logo
222 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
