Question about Garmin GPS
Just purchased zumo 450. map is not up to date. have loaded city nav nt to computer but not upto date either.
  • Garmin Master
  • 13,433 Answers
Hey, you can use the webupdated to update your gps
http://www8.garmin.com/products/webupdater/
Lets see about the map update it may need to be purchased. try the webupdated now first.
Posted on Sep 14, 2008
  • Ekse Sep 14, 2008
    Hey again the map updates are available here
    https://my.garmin.com/maps/updates.htm
    You will need to enter the serial number into the webpage and follow instructions
    Let me know if you need further assistance.
    Thanks,
    Ekse
2 Suggested Answers
SOURCE: maps
NO. YOUR SOLUTION NOT SATISFACTORY. NO HELP AT ALL
Posted on Sep 15, 2008
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Garmin Mapsource NT 2009 problem
your isp makes no difference and garmin should not tell you this. All the information you need should be on that dvd you bought. My suggestion is to disconnect from the Internet, uninstall the nt 2009, restart your computer, then reinstall the program without reconnecting to the Internet. This has worked for me in the past. My email address is cfoster16@comcast.net. If you need further help, I'd be happy to help you.
Sep 05, 2009 | Garmin SOFTWARE, MAPSOURCE CITY NAVIGATOR ...
Music on an 8GB SDHC card not showing up on Zumo 450
More than likely your Zumo will not recognize cards larger than 2 gb. This is not a problem with your device. They are not designed to use larger cards.
May 04, 2009 | Garmin zumo 450 GPS Receiver
Installed 2010 North America map in garmin Nuvi 205w....now Nuvi sez ther is no readable map for it to load
I just got off the phone with tech support. They have a very complicated fix that involves remote accessing into your computer and editing files, etc. They said it would take over an hour and a half, I declined. The problem apparently is that the nuvi 200/205 can't support canada, but the maps contain canada = problem. and btw, i downloaded "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" and got the same problem. this filename ends in a "B", apparently that's the "fixed one" but acc tech support it's only fixed in the sense that they can waste over an hr w' u fixing it, whereas the older files are unfixable.
I'm just gonna wait til they really fix it and upload those files.
Hope that helps.
Apr 17, 2009 | Garmin zumo 550 GPS Receiver
Need help unlocking maps in City Navigator NT North America.
I turns out that the unlock code was discreatly printed at the bottom of a yellow piece of paper in the packing.
Mar 21, 2009 | Garmin zumo 550 GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Maps
Sep 14, 2008 | GPS
I am updating my nuvi 200 with map update 2009 of city navigator north america nt. Canada is not loading to my gps through my computer. Looking for a solution.
when updating from the city nav update disc, it will only update the maps currently on the unit. Since Canada isnt included, it will not add it on. What you need is the Pre-programed City navigator chip for Canada. Normally retails around $59.99
Aug 04, 2008 | Garmin Rino 530 GPS Receiver
Nuvi 300
hi, i sorted out the problem with my sa nav, i went into the settings, then touched the map, and then touched the"map info" and then touched the city navigator europe nt+v8 and now i have the city/postal back. so now it's all done. hope this helps someone else. pete.
May 29, 2008 | GPS
Zumo 550
You'll have to select the europe map and deselect the usa map. Also you might have to change the locales. to do the first thing
tap wrench/tap map/tap about there you should see both maps, select the one you need and return to the wrench menu, select locales slect change all and walk through the menus (especialy the country!!!)
Aug 18, 2007 | Garmin zumo 550 GPS Receiver
GPS Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
