HP Omnibook xe4500 on boot up says PXE-E61 Cable missing; Operating System Not Found. Wha do i do?
  • gsk1985 Sep 14, 2008
    naguu, thank you for your help.
    On step 2, when i enter the bios i can see no startup nor boot so step 2 i cannot do.
    Also the PXE-E61 message is: Media test failed, check cable, followed by operating system not found.
    Any suggestions!?
    Sergeant:
  • 320 Answers
Selecting and un-selecting drives in BIOS can be a tricky process...let's try this: a) Step 1: go into BIOS, select F9 ( restore defaults) then F10 (save and exit). Re-boot. b) Step 2: back into BIOS, go into "startup" then into "boot" and choose "diagnostics". F10 to save and exit. Re-boot. You should be able to see both your drives (DVD and HDD) while "diagnostics" runs its course during boot. If you have a drive missing, there's your problem. If you don't have a drive missing, back to the previous idea: press F12, choose to boot from CD-ROM and see what happens this time around. Good luck and let us know. Install a fresh copy of windows xp. Thank you.........
Posted on Sep 14, 2008
  • Nagesh V Sep 15, 2008
    Sorry for in-appropriate answer. Your operating system is corrupted. You need to install a fresh copy of Windows XP. I think you have windows xp cd. Okay right. First you insert the Windows Xp bootable cd. And then restart the system. When any bootable cd is inserted into your cd rom that will automatically ask you to boot from cd. It shows that "press any key to boot from cd".. If not restrt the system again. Press Del key or F2 key(Continuously). It takes you to bios setup. There you can set the priority for cd rom. Check different tabs. IN any one if the tab there will be an option like Boot configuration. There you give the First propority to your cd rom. Press F10 for Save & Exit. Press Y and Enter. Now the system boots from your cd rom. Now you can go through the steps by windows. If you dont know how to install it, Please click on below link and note down the steps. Hopefully it should work...
    http://www.microsoft.com/windowsxp/using...
    Thank you.........
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
My laptop does not work it says PXE-E61:Media
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Cause:
PXE (pronounce Pixie) is an agent used to boot on to the network
It's using the DHCP protocol to localise a server where the image of the OS is located
In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
That is caused by the hard drive is missing, unplugged or failed
Jan 11, 2011 | Acer TravelMate 4062LCi Laptop Charger...
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Keep getting the following message when I turn on my Acer Aspire 5050 laptop: PXE-E61: Media test faulire, check cable PXE-M0F: Exiting PXE ROM Operating System not found
PXE bootup means the computer does not boot up from an operating system installed on a hard disk drive. PXE bootup uses a server on a network to boot up the computer.
It will not start without being connected the network that it was programmed to run on
Nov 16, 2009 | Acer Aspire 5050-3242 Notebook
Booting problems with acer laptop - no operating system found??
PXE (pronounce Pixie) is an agent used to boot on to the network.
This can be caused if the hard drive is missing, unplugged or corrupt, or simply by not having the boot order configured correctly.
When you start your laptops, press F2 repeatedly until you enter the bios set up, navigate to the boot order and make sure that the hard drive (sometimes listed as HDD....) at the top of the list.
Hope this helps, let me know if you need anymore help.
Jan 27, 2009 | HP Pavilion dv6000z Notebook
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
Computers & Internet Logo
366 people viewed this question
David Payne
David Payne
