Go to the store/website get your maney back/new one
Just click below;
http://home.howstuffworks.com/how-to-repair-an-oven3.htm
Hope it may helps;
In the actual oven the thermostat might be gone or there might be a problem with the switch or the heating element the best idea is to have a proffessional look at it since it could be any of those 3
Usually,
when an oven won't bake, it's because the bake element is burned out.
The bake element is the black, pencil- thick tube at the bottom of the
oven. When the oven heats, the element glows red. This element has an
expected life-span of several years. It may last for only one; it may
last for many more. When the element burns out, you need to replace it.
Here are two instances of when food "bakes poorly:"
You may get fooled into thinking it's
working, because the oven is hot inside. But many electric ovens use
the broil element, too, during the preheat and bake cycles. So the food
may be getting heated only by the broil element, which causes poor
baking results.
If the bake element is burned out, replacing
it should solve the problem. Otherwise, you need to further
troubleshoot the oven's electrical system to locate the defective wire
or component.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic
ovens with a digital display use a sensor to monitor oven temperature.
To solve temperature problems for these models, you may need to replace
the sensor. On some digital-display models, you can calibrate the
temperature using the key pad. See your operator's manual for details.
Ovens
without a digital display often use a mechanical system for controlling
temperature. On many of these units, you can remove the thermostat knob
and adjust the knob itself to more accurately represent the actual
setting of the thermostat.
If, when you remove the knob,
there's a screw on the back of it with a small calibration plate, you
can loosen the screw, adjust the plate, then tighten the screw again.
If the knob isn't adjustable, and the oven temperature is off by more
than 30 to 40 degrees, you need to replace the thermostat to solve the
problem.
SOURCE: Kenmore gas stove doesn't heat properly in bake
hi
the heating element is coroded better to change the heating element first clean the gas valves...
thank you......
on this model you cant see the bottom element
how do you get to hidden bake element?
