Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Spacemaker? Digital Coffeemaker-overflows during brewing with grounds everywhere.
I bought this thing a few months ago (I loved the old version of it so I got a new one when it died) It's great....when it works. It is nothing but a huge pain in the **** when it doesn't-which is almost every other brew session. What happens is I use the correct filters, dump in the correct type and amount of coffee into the filter basket. Water filled properly in reservoir. Turn on. Coffee is brewed perfectly 2 out of 5 times. When it fails...the filter basket overflows (seemingly indicative of a clog) and the coffee grounds end up in the decanter and everywhere else. The filter basket is full of water and grounds and only s-l-o-w-l-y drips out the nasty mess for my drinking pleasure. I clean this thing out thoroughly every time this happens with vinegar brews and to be safe ...I run a water check "test" brew to rid anything that might have been missed. I also checked the "spring" mechanism and the decanter's placement is not skewed off-center or missing the lever. Everything should operate properly, but it doesn't. I just finished cleaning up the latest mess. The brewing session the previous morning was fine. What is the deal with this thing! Instead of having a nice cup of coffee to wake me in the morning or sooth me during the is my blood pressure going through the roof every time this happens that gets the credit. I am ready to give up. KBL, Upstate NY
  • kibble_345 Oct 25, 2008
    Yup. It's the dang spring. It would "pop" the basket out of place just enough for the tab to close. Cool. I actually watched this takes about 5 seconds after the drawer is pushed back. What I did was remove it (the spring) and stretch it a bit. Works poy-fectly and I love it now! Thanks! Yojak FixYa Master-you ROCK!
    KBL, Upstate, NY
  • Anonymous Mar 22, 2014
    Hi I have a problem where the water will overflow inside the basket causing water and grounds to spew out. I have tried different filters but nothing works. Please help!
  • 30 Answers
I've read of this problem from other users of the newer Spacemakers and believe I know what's going on. Black & Decker used too strong a spring in the mechanisms involved in the "sneak a cup" feature which keeps the small tab or finger underneath the basket from opening and allowing the coffee to run into the decanter.
My suggestion would be to make certain that the tab that presses against the bottom of the basket is open when you insert the carafe. Not owning one of these units I can't state categorically that this will solve your problem, but all of the Spacemakers are fundamentally the same, just some cosmetic and design differences between them.
If it turns out that the tab is open when you go to bed and the basket still overflows it's possible the spring is so strong that it's moving the carafe away from the back of the unit, causing the tab to close against the basket. If that's the case I would figure out how to remove the spring without breaking anything in the process, then take it down to your local Ace Hardware and get a same sized but weaker spring. That should solve the problem permanently.
Posted on Oct 24, 2008
  • Oshawax Mar 09, 2011
    I have the same problem and the easy lo-tech solution is to wrap a piece of ribbon or such-like around the unit and carafe, holding it tight against the housing. Untidy but works 100%
  • mike95421
    mike95421 Feb 11, 2013
    Just pop that thing right off! Problem solved! Works like a charm 100% of the time no matter what type/grade of filters and even if you get 2 stuck together......."Sneak a Cup"? Some things in life are worth the wait!
Why is the coffee spilling/leaking everywhere during a brew cycle?
wrong filter possibly my Bunn does that with non bunn fliters
Apr 14, 2015 | Conair Cuisinart DTC-975 12-Cup...
Need a manual for JWX27
You can find the manual for this coffeemaker directly at the following link (for as long as it lasts):
With this coffeemaker, you can brew with the cover open. I recommend observing a brew cycle to see if the coffee with floating grounds are overflowing the filter into the strainer basket. If this is the case, inspect the strainer basket's valve to make sure it is not blocked and working properly. Also make sure the pot is fully in place so that the lid aligns properly with the strainer basket to open the valve adequately. Otherwise, the filter and/or the coffee grounds are too fine. I recommend a permanent filter basket (around $5) and course-ground coffee. Both will add to better tasting coffee.
Oct 08, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
Coffeemaker shuts off in the auto brew cycle
Your Cuisinart coffee maker probably is defective, though new.
Jan 10, 2018 | Cuisinart Chw-12 Coffee Plus 12-cup...
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
I have a cuisinart dgb 650 series coffeemaker and the carafe top is partially clogged resulting in coffee spilling over the top of the canister. How can I disassemble the lid of the carafe to clean it?
Unfortunately the lid is one unit. What you can do is try decalcifying the lid by soaking it in a water/white vinegar solution. If that does not work you might have to purchase a new lid.
Nov 11, 2010 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Shuts off in the middle of a brew or loses auto brew
In the last few months, my Cuisinart DCC-1200 Coffeemaker has started shutting off in the middle of a brew cycle and if I set it the night before, it doesn't start brewing at the time set for. At first I thought it was related to the GFI outlet I have it plugged into, but now I am convinced it is the coffeemaker itself. Since it is now about six years old, it doesn't owe me anything, but I will consider a different model for a replacement.
Nov 17, 2009 | Cuisinart DCC-1200 Coffee Maker
Machine will not brew at all, but is getting power
Are you sure that it isn't getting hot? I am having the same problem, but the plate is getting hot. I think there is a valve inside that prevents the machine from brewing once the plate reaches operating temp (so that the holding pot can't be overfilled). It's my assumption that it is stuck. Fill the reservoir with ice cold water and let it sit as long as possible. I let mine sit a day or two and the machine worked pretty well this whole week.
mine is not even a year old. I bought it 9 months ago.
Jun 04, 2009 | Cuisinart Coffee on Demand 12-Cup...
Clean button keeps blinking
Unplug the coffeemaker for one hour, and the self-clean light should come off.
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DCC-2000
Seems clogged
The problem may be caused not by a check valve in the inlet hose. This little gadget, about an inch inside the heater end of the tube, allows water to flow into the heating element but not back -- unless it's broken. This hose is the one closest to the outside edge of the bottom.
I'm sure *someone* must sell a replacement part, and I'm in the middle of that search. But I did get an older, broken coffeemaker from my brother (another member of "the Slow Wastebasket" society!
I was able to disassemble my Model CBC-00PC2 using a standard Torx 10 screwdriver. However when I tried to take apart an older model, DCC-1200, I found that it used the security version of the Torx 10 screw: it has a tiny nipple (correct word?) in the center of the screwhead that prevents a standard Torx driver to fit. I was unable to find the correct screwdriver and a security Torx bit is too thick to fit, so my brother and I resorted to brute strength to pop of the bottom.
The only other problem I had was that the older hose was a bit brittle and both the older and newer ones had sort of welded themselves to the aluminum heater element tube. Luckily, there was enough extra length and I was able to make it fit -- barely! I lost one of the little metal clips so substituted a tiny cable tie.
Everything seems to work. Oh, the only reason I knew about the check valve is that I previously disassembled the thing to see what was wrong and I found something (probably a piece of the valve!) floating around.
Hope this helps.
Nov 18, 2008 | Cuisinart DCC-1200 Coffee Maker
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
317 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
