Question about Miele Washing Machines
Miele Washing Machine Model W2659i Cleaned the drain filter. a lot of water came out Now showing "Waterproof Activated. Close Stopcock" Can't get rid of message.
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: waterproof system activated. close stopcock. The
Hi, it's caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie. Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work. You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics
Posted on Mar 05, 2011
Water is draining from the filter drain nozzle Miele W827
washing machine drain pipes need to be into a stand pipe that is as high as the sides of the washer .
Sep 21, 2016 | Miele Washing Machines
I have a Miele W 2389. Message saying waterproof system has activated. Turn off stop ****. What does it mean?
Hi Dear. Seems like your machine had internal leak. Float switch has been activated. That triggers error message on the display. What you can do is: Tilt the machine 45 degree (Back or forward which ever easy for you) wait for leaked water come out underneath the machine. If water comes out of machine, it's a indication of one of the plastic component failed(it could be drain hose- tub to pin trap hose- may be inlet valve etc....) If there is no water coming out of machine, float switch may be malfunctioning. In that cases you need to contact Miele center to get help.Thanks.
Apr 17, 2016 | Miele Washing Machines
My washing machine is a Miele and it wont start it is saying waterproof fault what can I do Please?
Have you tried to clean the filter recently ? If you have , water may have seeped into the machine, tip it forward and the water should drain out , if it does the same error you have something leaking inside the machine.
Mar 03, 2015 | Miele Washing Machines
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
Miele WT2670 message on screen "waterproof system activated". How do I reset?
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Jul 17, 2009 | Miele Washing Machines
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Waterproof fault
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
2. Unplug it
Jun 19, 2008 | Miele Washing Machines
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novotronic w930i washing machine
The machine thinks its flooded. Simply remove the drain cover filter and tilt the machine forward until water stops running out. Turn on machine and problem solved
Oct 02, 2007 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
