Question about SanDisk Sansa e260 MP3 Player
I have a sansa e260 and it connects and charges on computer and program can be located but computer is not reading that it is connected so can't sync it. Can you help? Thanks. Michele
I found another complaint similar to mine and someone had posted a solution, which also worked on my daughter's Sansa e 260.
I went to settings, then usb mode and selected MSC instead of MTP and computer instantly recognized the hardware and I could sync her music for her! Can't remember name of person who'd posted solution, but thanks heaps!
Posted on Sep 15, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Hi I bought scandisk e260 without cd, when I connect it to the computer, the computer ask me to locate driver. Where can I get driver? thanks
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e260 dosent read in the computer
well if you are trying to use itunes, then it won't show up. Only ipods or iphones do.
Nov 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
Substitute REC fo volume + in the following:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 16, 2008 | SanDisk Sansa e250 MP3 Player
Sansa fuze
I have a problem...my one makes all of the songs sound watery (the singinng)...
Jul 21, 2008 | SanDisk Sansa e260 MP3 Player
Sansa E260 won't power up on its own
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 17, 2008 | SanDisk Sansa e260 MP3 Player
PC cannot detect Sansa e260
-Tha Mp3 Doctor
Apr 20, 2008 | SanDisk Sansa e260 MP3 Player
Software needed
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Recovery tool
PDF on how to use recovery tool
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
Help
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Jan 04, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
