How to install and set up a VR 750 Phillips Video Recorder
  • 3 Answers
That doesn’t, have power on and play, when you insert pre-recorded tape. The on-screen displays are a bit odd too, the main menu is called up using the auto-install button, which only works when the VCR is in standby mode.
Posted on Sep 14, 2008
No video is played back on the Roland VR-5? only audio
Try reading the instructions again. I am assuming you have other videos that play.
Mar 22, 2014 | Roland VR-5 AV Mixer/Recorder
Tip
Import Error 0x80048003 on DVD-VR with Pegasys and TMPGEnc Products
Typically a DVD-VR media format is in ISO9660, UDF v1.02 with an import label of DVD-RECORDER and the preferred Media format is that of DVD+RW that can be written on without finalizing a erased several hundred times before it fails.
If you are trying to import a DVD-VR created on a DVD Recorder into your PC for editing and re-encoding you might get this error with either the excellent TMPGEnc Authoring Works v4.0; TMPGEnc v4.0 Xpress or the TMPGEnc MPEG Editor v2.0
When using the preferred media format of DVD+RW It might be able to find the VIDEO_TS folder and software like VSO Inspector OR Nero ROM's Info Tool may also indicate that the DVD-VR has track information on it as shown below
Possible Faults :
  • Corrupt VOB or VOB's this is the most common fault.
  • The DVD+RW reads in the DVD recorder as BLANK means that it has not authored the media correctly.
  • Faulty DVD+RW media that can only be used a finite number of times, you need to bin it and buy new media and try to record the Video again for re-import.
  • The AUDIO_TS folder is missing.
Possible Solutions:
Create an ISO file using Lightning's Excellent ImageBurn then import the DVD-VR from a mounted drive you can either use Slysoft's Virtual CloneDrive OR Alcohol 52% FE to do this make sure that you read at about X2.4 or slower and check the ignore read errors shown in red in the Settings Menu
Use DVD Shrink great user guide by Mr. Bass there also to try to import as much of the media as possible it might fail however but you will find out where the DVD-VR fails on the import it will also save the files that it has imported correctly for you which is a bonus and save them in a folder called DVD_VR or whatever the DVD Recorder labels the media as.
In this case DVD Shrink throws an I/O read error 19 seconds before the end of the track or 65% good files fails on 66%
This case shows a DVD-VR that has 10 good files however the last three VOB's of the DVD-VR format are unreadable hence the 0x80058003 error on DVD-VR import.
If you use Total Commander you can copy the 7 good files to the Harddrive and use evilmaster's excellent VOBMerge v2.51 remixed to join VTS_01_1 to VTS_01_2 together as the IFO files are still intact this will work and you will be able to import the resultant file for editing.
This is not ideal however you will still be able to retrieve about 50% of the video data from the corrupt DVD-VR from the first 2 complete Video Object Blocks (VOBs)
Even if your VOB's are not consecutive like in this example you can still join them and import then using the Add File Option or add the individual VOB's as long as the video that you want to edit is on the good VOB then you are OK.
Each one contains typically 30 mins of SLP DVD-VR video (MPEG-2 @ 720 x 576 4,380kbps 25fps) you may also need to change the file extension of merged.vob to merged.mpg to avoid any import errors although in my experience VOBs will import correctly in the latest versions of the software despite the warning shown below.
on Apr 05, 2010 | Pegasys DVD Author (123594)
We would like to buy the Edirol V8 video switcher for live internet broadcast. I need to know if this is the correct product for us. We have 3 cameras and a projector going into the switcher and then it...
Dear crane_editor,
For broadcasting the video signal coming from the V-8 over the internet you need to have a computer that is equipped with a composite or S-Video input card. Additionally you might need an audio input as well with the possibility to delay the audio to have a live stream with lipsync audio and video.
Roland has launched a new product recently which is actually designed for live streaming applicatons like this. It's called VR-5 AV Mixer & Recorder. This device has a USB streaming output for easy connecting with a computer. The computer will recognize the VR-5 as a USB audio/video class device (like a webcam) so your setup is ready in minutes.
Further the VR-5 is equipped with an audio mixer (with delay for lip sync), built-in preview screens with touch select, PC VGA input, media player and AV recorder (SD card).
Probably the VR-5 covers all of your needs, without the hassle of difficult configuration of all kinds of separate devices.
Kind regards,
Kees
Sep 22, 2011 | Edirol / Roland V-8 Eight Channel Live...
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
What is VR mode and Video mode on a dvd recorder?
ne sesito plano de este equipo urgente aiwa cx-naj50u
Aug 13, 2009 | LG Audio Players & Recorders
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Go video DVD/VCR recorder Model number VR-3845
First make sure you are using a quality disc like:
memorex Brand dvd-r.
Dec 25, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
