Question about Electrolux ICON 30 in. Double Wall Oven
Electical boxes The electrical boxes are located on top instead of the bottom as recommended in the product installation. Is there any way around this other than moving the boxes?
  • 979 Answers
No,not really. You may be creating a real mess.
Posted on Jan 29, 2009
Location of oven sensor
usually located inside the oven near the top left but varies in other models, at bottom, at top, it looks like a tiny thin pc of tube or metal or glass and held by a couple screws
Mar 01, 2015 | Dacor ECD227 Epicure Electric Double Oven
After electical outage my Jenn air JJW9230dds is dead?
Check the Main electrical Box for a fuse or circuit breaker that turned off.
Jan 07, 2014 | Jenn-Air JJW9230DDS Stainless Steel...
HotPoint model# RB787WC4WW : Clock is functioning, all lights are on, but the burners and oven won't function. Is there a fuse or relay on this model ,and if so where is it located. I've taken the...
your oven may be on a 3 phase connection that mean you have 3 supplies to it.
one phase may be running the clock and fan etc.
the other two maybe for the burnters .
check in your house fuse or trip switch box and ensure that all trips are on and or fuses are not blown. this is usually where your electic meter is located.
if this is the case switch the circuit back on, if the fuse goes again this may indicate a fault either in your home or with your oven. if so call in an expert to check.
warning. high voltage electricity is dangerous if unsure call out a qualifed electrician or speak to your electicity supplier for advice.
i hope this was useful
Dec 11, 2010 | Hotpoint Ovens
How do you clean the inside top of the oven where the element is. or does it self clean
There are several products available for cleaning ovens.
I would recommend that you get a spray on type.
This will enable you to get in the awkward places.
After leaving for a while, you simply wash it clean with cold water.
Please leave comment on my recommended course of action.
Thankyou.
Nov 25, 2009 | Zanussi ZBF360X Electric Single Oven
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electrolux ICON 30 in. Double Wall Oven Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
