Question about Kenmore 22422 Top Load Washer
Kenmore Top load washer won't drain
We had a power outage in the neihborhood where the lights went out for a split second, my washer machine was on at the time. Now it does everything except drain, I don't hear the pump at all , after the spin cycle is finished it just shuts dwon and is silent. Could it be the pump just got burned up when the power surge happened or a lid switch?
Thanks
Paul
    President:
  • 1,462 Answers
Nothing would work at all if lid switch were faulty. connect drain pump independently to mains and that will tell you if pump is faulty.
Posted on Sep 14, 2008
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Washer will wash but won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
My aunt has a Kenmore Elite range and it begam flashing a "PO" error message. Can you tell me what this means?
PO means power outage so if ya has a lighting storm or for some reason if the power went out thats why it says that . Push clear/off for 3 -5 seconds and codes should go out
Aug 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
PF error code on kenmore elite
PF stands for Power Failure. Caused by unplugging and plugging in within 30 seconds, or a short power surge or outage.
Dec 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore model 22642 top loading washer leaks somewhere from the bottom. I turned it over and couldn't see any obvious wet spots. All hoses are secure.
follow your drain line back into the bottom of the machine, there will be a box like plastic part that it hooks up to. I have had the plastic split causing it to leak during the draining cycle.
Dec 30, 2009 | Kenmore 22642 Top Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 22422 Top Load Washer Logo
96 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
