Question about LG BG8000ER Air Conditioner
Lg 18000 remote with heater
I got my lg about 3 months ago it's worked fine but 2 days ago it started making a sound like the fan was hiting something we turned it off couldn't fined anything turned it back on it made a loud bang then it word fine but it vibrates it so heavy i can't pull it out to look at it. roger boyle
  • 958 Answers
Your fan blade hit something and i think one of the blade got damaged and somehow it is no longer balance and makes a lot of vibrations.
have you read in the instruction manual to remove some kind of a shipping support before running the unit?
im just curious what hit your blade. it could be the shipping support for the compressor.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
Faulty m.board could burn newly replaced itens? - GSS25KGMDWW
i dont believe ur mother board is gonna be ur problem its either gonna make something turn on or off not burn anything up unless it jus totally shorted out and sent power surges to the parts ( highly unlikely)
Feb 24, 2010 | GE GSS25LGM Side by Side Refrigerator
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
JCD2295HES side by side not working correctly
yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Mar 05, 2008 | Jenn-Air JCD2295HES Side by Side...
LG BG8000ER Air Conditioner Logo
117 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
