Thomson DTI6300-25. Flashing red/amber light will not become steady. Looks like it's failing to boot up. left for at least five minutes but still flashing
  • 4 more comments
  • pykechan Oct 11, 2008
    Hi my tv ,thomson 52RW77WA wont turn on.All it does is red light flashes the ON /off button.No picture.
  • Anonymous Mar 31, 2009
    Identical problem, these boxes are gash!
  • manksman Apr 06, 2009
    Orange light started flashing when pressed "Guide" now won't reboot.
  • DaveTRave Apr 19, 2009
    Thomson DTI6300-25. Flashing red/amber light (looks orange)
    Constantly flashing, tried leaving on, turning off (half hour)
    No change.
  • Smallfry66 May 04, 2009
    You think you guys have it bad, well I unfortunately have 2 of these Thomson boxes and last night the 2 of them have EXACTLY THE SAME flashing lights and it's driving me crazy, I know things break down but it so frustrating to lose EVERYTHING you have recorder
    DAM & BLAST these PVR's
    Any one out there help???
  • Anonymous May 05, 2009
    The same....clearly a linux issue but not hard disk as i can hear it working...
  • 59 Answers
Check all the caps in power supply the two i found on a Thompson rear projection set where 2,200 35v and 330 16v plus soldered up dry joints on main board
Posted on Aug 14, 2009
    Genius:
  • 2,920 Answers
Check the power supply
Posted on Sep 14, 2008
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Cant seem to connect to the internet local access only
Connect Modem cable to Modem port of the Belkin Router Check the light status Flashing Amber-- Issue with Physical connection (Check Cables) Steady Amber-- Needs to be configured Follow these steps Open Web Browsers like Internet Explroer or Safari Type in Web address bar 192.168.2.1 For Password Leave the BOX blank and click on submit Torwards the left side you can find Restore Factory Defaults Click on it Restore Defaults> Click on OK for Disclaimers Then select Connection Type, then select Dynamic>Host name ( put your computer name)> Click on SUBMIT
Select MAC ADDRESS( towards left side)> select CLONE
Then Reboot both Modem and Router Hope it will fx the issue for You
STEADY GREEN-- Ready to use the internet Flashing Green--- Router is booting up
((((((FOR HARDRESET -- Behind the router you can find reset hole... Press and Hold with any sharp object (toothpick or Paper clip) for 40 secs))))
Dec 09, 2010 | Belkin Basic Wireless Router
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
My thompson dtr box will not turn on now.it stays on an amber light and doesnt want to do anything else.1day it was fine,now its not.
Message taken from TopUpTV
Does your Thomson DTi6300 fail to power on normally and displays a solid amber light? During the past few days we have been made aware of an issue affecting a number of our customers with a Thomson DTi6300 box. Customers have been experiencing problems with their box failing to come out of standby mode and typically showing a constant amber light on the front panel.
This fault is due to a broadcast issue which  has led to a corrupt file being loaded onto the hard disk.
Only Thomson DTi6300 boxes have been affected. If you have been experiencing problems of this nature first of all try switching your box off at the wall and leave for twenty seconds. If this does not work, please try the following procedure.
Please note this will unfortunately cause recordings in your programme library to be lost which we?re very sorry about. You may have to try this procedure a few times in order to resolve the issue as it requires complete attention and precise timing.
1.       Disconnect the power supply from the unit by removing the power cable from the back of the box.
2.       Wait 20 seconds and then put the power cable back in while pressing the 'standby/power on' buttonrepeatedly on the front panel of the box.
3.       Release the standby button as soon as you see a light flash on the front of your box and thenimmediately press the arrow buttons on the front panel quickly and in the following sequence:  Up, Down, Left, Right (please note this is not the order the arrow buttons appear on the box).
4.       Your box should then show the amber light with the green light flashing until the disk re-format has been completed which will take around 60 seconds. The box should return to a solid red light (standby) automatically. If after 2 minutes your box still does not display a solid red light, please repeat steps 1-4.
5.       When you return to the TV GUIDE screen, you will now need to scan for channels to restore your Top Up TV channel logos. To do this, please select Option 4 (set-up) from the Main Menu, followed by option 1 (scan for channels).
6.       IMPORTANT: Once you have completed your channel scan, you will need to select option 5 from the Main Menu (Choose your channels) to re-select all those channel providers you would like Top Up TV to download shows from.
We?re really sorry if you have been affected by this issue and greatly regret any inconvenience this may have caused.
May 06, 2009 | Televison & Video
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
May 04, 2009 | Thomson DTH8000 DVD Recorder
Thomson DTI6300-16, The amber light constantly flashes, no red or amber lights appear! any help/advise would be welcome
May 04, 2009 | Televison & Video
My thomson dtr
just found this solution and it worked for me ............. though it wiped the hard drive ............ basically restores to factory settings
turn all power off and back on again press stand by button repeatedly until flashing amber light is n constant them quickly press up down left right in that order as quick as you can .............
good luck
Nov 11, 2008 | Televison & Video
Thomson DVB Top Up Box
www.digitalspy.com/forums/showthread.php?p=31773855
IF you're lucky, this may help....?
This restes the bios but removes all recordings from the hard drive.
Good luck!!
Oct 09, 2008 | Televison & Video
Thomson dti 6300 freeview box will not come on just shows constant red/orange light flashing all the time, tried leaving power off etc....anyone know?
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Apr 13, 2008 | Televison & Video
Televison & Video Logo
673 people viewed this question
Top Televison & Video Experts
