Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Changing nat on xbox live
Please help me change my nat too open
  • 5 more comments
  • GAMEZILLA Sep 20, 2008
    i need help to change my NAT to OPEN it is on Moderate right now i need it to play on xbox live i have the Belkin  G Plus Mimo_39251E
  • Anonymous Sep 25, 2008
    i cant play my friend on xbox live. his NAT is open and mine is on moderate. is this keeping us from playing? if so how do i change settings to open, i have a linksys wireless G WRT54G router, please help
  • Anonymous Oct 09, 2008
    need to change from moderate to open
  • Xris21 Oct 09, 2008
    I have the same problem. Except that about two weeks ago my nat type was open, so if its changed (although i haven't changed anything) how do i change it back?
  • Anonymous Oct 24, 2008
    Yes am said strict.
  • Doc Zero Dec 09, 2008
    my nat is strict and i have restart but nothing changed please help
  • robertv49 Dec 26, 2008
    how do i get to my routor settings
  • 4 Answers
I had this issue, and solved it recently. Everyone on the internet will tell you to forward ports, or disable the NAT setting, but these never worked for me. As I was about to give up and buy a new router, as a last resort I decided to call tech support. In about 3 minutes they fixed my problem, and it is much easier then port forwarding.
-First go into your 360 network settings and find its mac address.
-In the router settings move to the LAN tab.
-Then go to "dhcp leases".
-Under "current dhcp leases" your 360 should be listed (match the mac address)
-Make a note of the IP address listed for the 360, then delete that lease.
-Now Reserve a new IP address, enter in the MAC address and IP address you wrote down for the 360.
-Check the bypass firewall option (and give it a name if you want) and then add the new entry.
-On the same page, move up to "DMZ Host" find your new entry and click "apply"
-Click the option to reboot your SBG900, then restart your 360, and the NAT should be open.
I hope this helps, if I described it correctly it should be much easier then port forwarding, and more importantly, it should work.
Posted on Nov 15, 2008
Http://www.portforward.com/english/routers/port_forwarding/Motorola/SBG900/Xbox_Live_360.htm
Im not sire what your trying to open it for but try this website it gives you step by step directions. I opened my nat specifically for x box live. This may work for you if you habe the port ending and port begining numbers. This is safer than just having open NAT.
Posted on Sep 19, 2008
You have to change it in your router setup page. Go to a web browser and type 192.168.1.1 (default)
Posted on Oct 04, 2008
3 Suggested Answers
33mlake33
  • 142 Answers
SOURCE: Change NAT to open
You need to call xbox live tech support. From there they will give you a code. This code will need to be entered in the settings for you wireless interenet product under "Port range forwarding."
Posted on Dec 29, 2008
  • 561 Answers
SOURCE: How do i change my NAT type to open for Xbox Live
Hi
Thank you for your query
It is not the NAT type you need to open
This is one of a 1 or 2 step process
1) Ensure that the port you are using for your Xbox is open on any internal firewall you may have installes e.g. zonealarm etc
2) Log onto your modem router, there will be a option for gaming DMZ, in this selection ensure you open the apprpriate port for the Xbox
3) Enjoy :)
Please can i ask that you leave feedback and vote if this has been useful
Posted on Feb 12, 2010
Xbox nat setting
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Mar 07, 2010 | Microsoft Xbox 360 Controller
I need to open my NAT type for xbox live
You can contact NETGEAR support to help you open the NAT settings. ( they know how to do it )
Note:
The simplest way and most efficient way to connect to xbox live is using DIRECT MODEM CONNECTION
For compatible list of devices and internet service provider, please check the website ( www.xbox.com )
Apr 14, 2009 | Microsoft Video Game Consoles & Games
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Change NAT to open
Look through the menu's on the router for UPNP. Turn it on. Then turn it on on the XBOX. UPNP is Universal Plugand play. that should configure the router for you automatically.
Dec 05, 2008 | Zyxel P660HW-D1 Router
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change NAT to open
Here you go sir, follow the instructions in the link below and your Xbox live will report an OPEN NAT and it will fix your connection problems.
http://www.portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/Xbox_Live_360.htm
Hope this helps!
Feb 09, 2008 | Belkin (F5D7230-4) Router (587009)
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
3,400 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
