Question about Brother XL-6562 Mechanical Sewing Machine
Lower thread problem
I have a Brother XL-6562 machine. I was hemming my son's jeans. I have a denim heavy duty needle in the macine. It was a little tough getting over the side seam, where it was thick, but I found if I pulled it through, it would go through ok. I went through a side seam, then finished the hem. It seemed to be fine, then I went to start another hem and the machine makes a sound, the bobbin seems to be jumping around and the lower thread just bunches up and tangles. The material stops feeding due to all the tangled mess on the bottom. I've tried re-threading. Any suggestions?
Thanks.
Amanda Lambert
alynnlambert@aol.com
    New Friend:
  • 3 Answers
Are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Posted on May 21, 2009
  • 1 more comment
  • Greg Isgood Aug 16, 2011
    I would like to read the answer
  • smbornagain9 Aug 16, 2011
    It's been a while since I had this problem. The first thing to check for is to make sure you have proper tension on your presser foot. A lot of times when you start a thick seem like that, folks will forget to put the presser foot all the way down. Secondly make sure the thread in the bobbin is turned in the correct position so the thread comes off in the recommended direction. Use the proper size needle for thread and fabric size. A size 14 is recommended for bluejean fabric. Also use a scrap piece of the fabric your sewing with at the thickness your sewing with and check your thread tension, compare to chart in owner's manuel.
    Last but not least a trick to going over thick seems without bogging down your machine is to balance the presser foot. Basically you get a scrap piece of fabric and fold it to the same thickness as your seem. When the front of the presser foot comes in contact with the seem, you stop sewing, lift your presser foot, place the scrap fabric under the back of the foot, behind the thread, so as not to catch the scrap fabric in the needle. Then put the presser foot back down and sew over the seem. As the foot goes down the other side of the seem, you simply move the scrap fabric from behind around to the front, leveling the foot, but being careful not to sew into your scrap fabric.
    Last tip is to say that, if you've gone over a thick seem incorrectly, you can very easily damage your machine, and it is impossible to fix without the proper equipment. Hope this helps.
    Oh and I forgot to mention that if you've pulled your fabric, the needle is probably now bent and needs to be replaced. That would explain why now the thread is not catching on the bottom like it should be.
Tension setting for sewing denim on brother LS 2125
Refer to 'Manuals Online', Brother sewing machine user manual. There is an excellent guide to tension settings for all fabric types. Also remember to check upper and lower thread has been wound through correctly and are using the same thread top and bottom. Ensure you have the correct needle size for denim ie 100/16 and the correct thread size ie 40-50 cotton or heavy duty polyester.
Nov 09, 2016 | Brother Sewing Machines
I'm trying to sew jeans hem and stitches are uneven on top and loops are showing underneath. Also the foot and needle will not sew over cross seams and thread keeps getting snarled up underneath. Tha
a lot of machines struggle with denim because it is such a heavy and dense textile. Many domestic machines won't stitch it at all due to this. Things you can try however:
  • Denim needle, this has a deeper groove at the back and is a heavy gauge needle, or use size 110 if you don't have denim needle.
  • Bash the side seams with a hammer in the area you will be stitching, to soften up the fibres.
  • Use a seam jumper, this is a piece of plastic to put in back of the presser foot as you approach a cross seam to help keep the presser foot pressure even across the fabric. Sometimes called a "thingy-a-jean" or similar.
  • Don't bother trying to use the heavy gauge yellow jean thread unless you put it through the bobbin and sew with the right side down. But even then, many machines can't handle having this heavy thread underneath and the regular 50 cotton on top, my Janome 1600 won't do it.
  • put your machine on slowest speed if you have a variable setting and turn the flywheel to assist it through the heavy side seams.
Personally, I never bother with the twice turned hem on denim if shortening, I just overlock the raw edge, turn up 1 cm and stitch around in a matching blue thread so it is seen as little as possible.
Feb 03, 2014 | Elna Sewing Machines
Brother xl-6562
Check the clamp for a crack it sounds like it may have been broken. Good luck
Jul 21, 2012 | Brother XL-6562 Mechanical Sewing Machine
I have been sewing denim, and the top thread keeps breaking at the needle. What adjustments do I need to make. It also bunches from the bobbin.
Are you trying to use a heavy thread like buttonhole twist through the needle like the yellow thread on store bought jeans? Most domestic machines will not cope with this heavy thread and it will be too large for the eye of the needle too.
If you are using regular weight 50 polyester thread and its breaking then it could be because the top tension is too tight. Just loosen off 1/2 a number on top tension dial and see if this helps.
If possible, buy a pack of jeans needles size 100 too, these are blue coated with teflon I think, and makes it easier to slip through denim which is a very dense fabric.
Hemming denim jeans is probably one of the toughest jobs for a domestic sewing machine so if you are trying to do this, its a good idea to take it slowly and use a "humpjumper" which helps to maneouvre over the thick side seams.
However, even with all the above, many machines won't sew more than one layer of heavy dense weave denim.
Jul 20, 2011 | New Home HF-106
I cut off jeans and turned them up to hem. Following all the directions in the manual, I began to sew, but the thread broke after only a few stitches. My thread is all-purpose thread. I tried tips in...
I turned up my husband's jeans using a size 100 needle. You can get easy thread needles that have a small gap in one side that you slide the thread through. There is a good way to turn up jeans and keep the original hem without having to cut them. Have a look at this site http://www.daciaray.com/?p=38
Aug 25, 2010 | Brother CS6000i Computerized Sewing...
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Apr 20, 2009 | Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
I have a brother LS2125i it is easy to use, and I am a complete novice- but when I try to sew heavy denim- Like over the thickest part of the hem it makes a very load click nose- and becomes stuck--- is...
It may be the machine, although most machines would have trouble going over the seam. First, use a Denim needle, 90 or 100 and place a "shim" also called a "jean a majig" to keep the presser foot level. If the foot is shifted, the machine will not sew over the bulk. The machine is not real heavy duty, may have problems , anyway.
May 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother XL-6562 Mechanical Sewing Machine Logo
252 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
