Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Help! Error E 2 then E 3 showing on printer? what should I do????
The printer will not allow me to do anything! help!!!!
  • samuelwyc Dec 03, 2008
    i facing E3 error too,,,,anybody can solve tis problem..
    Sergeant:
  • 284 Answers
E2 = No Paper
E3 = Paper Jam
Posted on May 31, 2010
Machine shows "cover open"
No error code ## 343, but will not print now. How can I change from English to Finish languages in printer?
Jul 08, 2010 | Canon SmartBase MP360 All-In-One InkJet...
The printer shows error code 5100 I think it has
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Good Luck.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp140 not printing anything after refill
MY PRINTER'S ALARM LIGHT IS FLASHING AND SHOW ERROR 2 CAN YOU HELP ME ?
Oct 26, 2009 | Canon Office Equipment & Supplies
My printer keeps giving a paper jam error no paper is jammmed
hi....
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
if this doesn't fix your problem then u can go the following links....
1) http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
2) http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc240c_all.html?reg=us&c=us&lang=en&prod=mfc240c_all
if these solutions helps you then rate for my solution...
thank you....
Jul 19, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Printing error 5100; came in midst of printing multiple pages
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
Solution 1:
Solution 2:
May 12, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Kyocera FS3900DN Error 7410:0271683
push the drum until it clicks
power off/on
Apr 07, 2009 | Kyocera FS-3900DN Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Printer- On Line/Error
Download the status monitor for the ML-1710 and when you switch on the machine the monitor should help to give you an indication of what the error is. Post that info back here for further help. Unfortunately there is insufficient information here to help you further. The status monitor may give you an error code - this will help us help you further.
Sep 16, 2007 | Samsung ML 1710 Laser Printer
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
225 people viewed this question
old marine
old marine
