Click below for the manual guide;
http://www.manualshark.org/p/canon-3/canon-pixma-mp500-307/
Hope it may helps;
Regards,
VOTIT
Back to the ink problem,
remove all ink tanks
check & clean ink tanks & the ink tank holder (specially the contacts) with soft dry wipes
then re-seat them all
After reinserting the. ink tanks, there has been an error and the printer cannot print. ...... “Error Message Appears on the Computer Screen” on page 66 ... http://www.leoscamera.com/Digital/canon/ip3500_qsg_us_v1.pdf
The input tray has adjustable paper guides and slides out of the
printer's body smoothly--almost too smoothly, as there are no stops. An
additional input tray flips out of the rear of the printer, for paper
types you might use less commonly. This, too, has an adjustable paper
guide, but we found it hard to slide.
The service manual will be helpful to you in solving any problem with this printer try this solution from the service manual: http://soft-manufaktura.ru/manual/hp/mp500sm.pdf
Set the paper in the ASF, and press the OK button
Hope that helps..............
Hey,
Make sure the correct paper source is set
Clean any foreign objects from the machine
Press the On / off switch to reset the device
Paper Source
Press the
Check for Obstructions in the Auto Sheet Feeder (ASF)
If paper does not reach the Paper Edge Sensor, the LCD will show [LOAD PAPER].
Power off the printer.
Remove paper from the (ASF).
Look in the ASF area for an obstruction. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove the foreign material by hand, or with tweezers.
Open the scanning unit (printer cover) and confirm that there is no foreign material in the printer. If there is any foreign material, remove it.
Close the scanning unit (printer cover).
Power on the printer and confirm that the printer operates normally.
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
On the operator panel, press and hold the
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
Wait approximately ten seconds and then press the
Wait until the device has completed its cycling process before submitting another job request.
Do you still have the first problem on top of the 2nd one you posted?
When I clicked on the "soft-manufaktura" address you gave, I received nothing but a blank page eventhough I waited 15 min. Since we are in a rural area, we can have only Dial-Up and my computer is extremely slow. That solution did not help.
