Question about Refrigerators
Frigidare FRS20ZRG Filter housing replacement
Not sure how to get houing cover off with out braking it
  • 958 Answers
There is a filter housing wrench available for $4.56 at partselect.com
here is the link
http://www.partselect.com/CategoryBar.aspx?Var0=41&Var1=2&Var2=16
hope it solve your problem,
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
Need to replace the water filter tube on my Kitchen Aid KFIS29PBMS01 french door bottom freezer. How do you remove the water filter housing from the inside of the refrigerator to replace the tube?
Ok this is a hard one first take the two screws out near the filter just. That take a screw driver any pry the cover down start close to the ice maker side its held on with clips you will think its going to brake but just slowly pull it that back has hooks so once the front is loose don't yank use a flash litecyou will see three hook molded in the cover pull towards you the will come out disconnect lite harness and there will be a few more screw holding the housing up than you can get the filter out you do have to rotate the housing to remove
Oct 19, 2015 | Refrigerators
Hou do you remove the inlet filter to clean it? Kohler model so1t6944 whirlpool tub.
I am assuming you are asking about the suction cover. Usually those are held in place with a couple of screws or it simply unthreads counter clockwise.
Rod
US Parts Center
888-521-6183
Apr 11, 2013 | Home
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
Where is thermal fuse on a Ken more he4 dryer
The thermal fuse is located in the housing where the blower wheel is (its the same houing where the lint filter is) you can get to it by removing the small panel below the main front front panel.the fuse will be on the top of the housing an dlook very similar to this picture oldtech2332_130.jpg
GENE
Oct 10, 2011 | Kenmore Washing Machines
How to change air filter on a 2009 hyundai sonata
Hi there, here are a few steps to help you out:
  • Turn the Sonata off to eliminate the risk of engine backfires while changing the air filter. Leave the car off until the filter has been replaced or there is risk of injury.
  • Lift the hood of the Sonata. Locate the air filter housing unit on the passenger side of the car, in the front corner. Look for a black, plastic cylinder that has an accordion-type hose attached to it that leads to the engine.
  • Remove the air intake hose and air duct from the housing unit. Disconnect the connector for the air-flow sensor from the filter cover. Unclip the clip on the filter cover. Lift the cover off the housing unit.
  • Take out the old filter from the housing unit. Remove any remaining debris out of the air filter unit. Wipe the inner and outer surfaces of the housing unit with a damp cloth.
  • Place the new air filter in the housing unit. Use a K&N air filter, part number 33-2346.
  • Replace the cover on the housing unit and clip it in place. Reattach the air-flow sensor. Put the air intake hose and air duct back in place on the housing unit.
Best of luck....
Jan 13, 2011 | 2009 Hyundai Sonata
How do you replace a 2001 Mazda 626 Fuel Filter
Fuel Filter On all models except the Millenia, the fuel filter is attached to a bracket located in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir. On the Millenia, the fuel filter is located beneath an access cover in the trunk. Access to the cover is achieved by removing the trunk mat to expose the cover.
REMOVAL & INSTALLATION Except Millenia
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable Fig. 1: Exploded view of a common fuel filter and related components 7923mg68.gif
    • Air intake hose and/or filter housing, if necessary
    • Fuel line clamps, if equipped
    • Fuel lines from the filter and plug the openings
    • Filter clamp bolt/nut by loosening them.
    • Fuel filter from its mounting bracket
    NOTE: Note the direction of the flow arrow on the filter so the replacement filter can be installed in the correct position. To install:
  4. Install or connect the following:
    • Fuel filter in its mounting bracket, making sure the flow arrow is pointing in the proper direction
    • Fuel lines to the fuel filter
    • Air intake hose and/or filter housing, if removed
  5. Pressurize the fuel system and check all connections for leaks.
Millenia
  2. Insure the ignition switch is OFF.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Trunk mat
    • Service hole cover
    • Fuel lines from both ends of the fuel filter
    • Fuel filter and bracket
    • Fuel filter from the mounting bracket.
    To install:
  5. Install or connect the following:
    • Filter in the bracket. Tighten the nut to 70-95 inch lbs. (8-11 Nm).
    • Fuel lines to the filter
    • Trunk mat
  6. Run the engine and check for any fuel leaks.
Oct 17, 2010 | 2001 Mazda 626
Leaks at the filter of a frigidare side by side SXS FEFRIGERATO
Assuming this is a side by side, with the water filter located at the top back of fresh food side, assuming filter is unclogged, i.e., new, check the housing that the filter slips into, that which you actually grasp and turn to remove the filter. If there are any cracks in this filter housing, you will need to replace it. If the cover is sound, the problem will lie within the housing assembly, that which you screw the filter cover into. This housing is held on with 2 or 3 screws. IN order to remove the water lines, you must squeeze the white collar towards the housing, away from the water line, while at the same time gently tugging the water line. If you squeeze the collar correctly, the line should come right out. Make sure to connect ONE line at a time. Do not disconnect both and reattach at the same time. If the lines are reversed, you will damage the filter and possibly water system itself. attach water filter and check again. if filter cover is ok, and this does not fix your problem, without personal inspection, i cant help you further. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Can't locate air filter...
1. Loosen clamp (1) and disconnect air duct at air cleaner cover (3). 2. Pry over 4 spring clips (5) from housing cover (spring clips retain cover to housing). 3. Release housing cover (3) from locating tabs on housing and remove cover (3). 4. Remove air cleaner element (filter) from housing.
Jun 30, 2009 | 2007 Jeep Commander Rocky Mountain
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
2003 VW Beetle TDI
The oil filter is in a filter housing located on the top of the engine. Take the engine cover off. The 3, 10mm nuts are located under the circular pop-off covers that attach the plastic engine cover. You should see the oil filter housing to the right of the engine valve cover. The oil filter housing is a black, plastic cylinder with a cover that unscrews. The filter is inside of this. Make sure you drain the oil before unscrewing the cover to the filter housing.
Jan 11, 2009 | 2003 Volkswagen Beetle TDI
Refrigerators Logo
328 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
