Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite bottom freezer suddenly stops making ice.
Why would ice stop dropping? No recent moves or temp changes by us.
lollerz
    Genius:
  • 1,239 Answers
Hi The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Posted on Sep 14, 2008
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker just stopped making ice today....please help
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is making a creeking noise
I went in and knocked all the ice out and it started to work just fine.
May 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Loud fan noise near bottom of freezer on my kenmore elite
There is a fan down on the bottom of your unit it sounds to me like the fan is making the noise as the bearings are getting dry. You should be able to move the unit out from the wall and get behind and look at the fan right next to the compressor. let me know how it goes. ken
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
152 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
