Question about RCA F36650 36" TV
Power button When you push the power button,it blinks twice and shuts off. There is no picture or sound
Power light on tv flashes 3 times. no other activity
Posted on Sep 15, 2008
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Power light blinks red
Hello, If you can turn it back on with the s momentary key or power button:
When it shuts off, do you need to push the power button once or twice to get it back on? Also, does anything else about the picture or sound change as it warms up?
If once, then the controller is shutting the TV down either as a result of a (thermally induced) fault in the controller or it sensing some other problem. Monitoring the voltage on the relay coil (assuming these is one) could help determine what is happening. The controller thinks it is in charge.
If twice, then the power supply is shutting down as the controller still thinks it is on and you are resetting it. A couple of possibilities here would be low voltage or high voltage regulation error (excessive high voltage is sensed and causes shutdown to prevent dangerous X-ray emission). A partially dried up main filter capacitor could also cause a shutdown but there might be other symptoms like hum bars in the picture just before this happened. Clipping a good capacitor across the suspect (with power off!) would confirm or eliminate this possibility.
If it uses a pull-knob (or other hard on/off switch), then this may be like pulling the plug and would reset any abnormal condition.
May 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
The TV shut off by itself. Just before it went off, it said "timer off 0:00 press 09". Now when I push the power button the power light blinks and there is no picture.
sounds like somebody set the timer. normally this only makes the set enter standby mode and pressing the power button or a channel button usually wakes the set normally.
Just a longshot but have you tried pressing 09 while the light is blinking?
Mar 21, 2010 | Toshiba CZ32V51 32" TV
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
May 03, 2009 | Philips 50P8341 50" Rear Projection...
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Setting up 42lg3000 with sky and lg home cinema dvd system.picture and sound from dvd.poor picture and sound from tv speakers only from sky .please advise on correct wiring connections for this set up.TV...
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Nov 29, 2008 | Televison & Video
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Jun 19, 2008 | Televison & Video
No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Sep 06, 2007 | Sony KDL-32S3000 32 in. LCD Television
RCA F36650 36" TV Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
