Question about Maytag Heating & Cooling
Window unit stored upside down 1year, does it need to sit upright for any time before starting?
  • 958 Answers
Yup...let it sit for about an hour for the oil to come back to the bottom of the compressor before running it.
make sure also that the fan blades are freely turning, if they are binding a bit, try to re-oil the bushings of the fan motor.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
Goes off about 3 seconds after starting. Turned upside down and it ran without turning off. Already checked for blockages
When the light blinks and the unit shuts down it most likely needs to have its bag changed. You may find tha the bag is not up to the fill line, but is likely over a half. Our experience is to change the bag and the problem resolves.
Oct 12, 2015 | Oreck Magnesium Upright Vacuum Cleaner
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Jan 18, 2015 | Fisher and Paykel Refrigerators
Sanyo PLC-XT10A shuts off after 30 seconds
That is really odd maybe when its upside down something is barely coming loose or a fan is getting blocked?
Dec 08, 2012 | Sanyo PLC-XT10A
Fridge working but not cooling
Sometimes they need to sit for a while after they have been moved, to allow all the refrigerant to settle back where it should be. If you had to put it on it's side / upside down to clean it, then maybe if you give it a few hours sitting upright it might start working again.
Also (I am not familiar with that exact model of fridge) are there any switches or dials that may have been moved during the cleaning process?
Oct 03, 2012 | Engel MD14F Fridge / Freezer 15 Qts
Dell 5100mp projector fan is quiet when doing presentations on table top, but makes noise when ceiling mounted for home theatre. Noise get better after 20-30 minutes, but is just as noisy next time i...
turn it on when sitting on a table right side up. If possible, take the cover off and support carefully nearby the unit. Then slowly rotate the unit upside down and notice when the noise starts to get worse. Have a look at the fan area and see if there is anything that's causing the fan to make a worse noise. perhaps the bearings are getting worn out or something's not as titgh and vibration is being amplified by the fan unit.
Jun 07, 2011 | Dell 5100MP Multimedia Projector
Bought used window unit. I opened the box and it was upside down. There was no indicators on the box for right side up. When I took it out and set it upright, I noticed oil was all over the unit. I let...
When any a/c compressor is turned upside down, you will have a burn out when it is turned on. The oil runs down into the system and mixes with the freon, this will cause the compressor to burn out with in minutes. Even if your leave it upright for 24 hours, you may get lucky and it will run, but I am glad you got your money back or you would be stuck with nothing but junk.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Feb 16, 2011 | Amana ACD105E 10000 BTU ENERGY STAR ROOM...
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Danby 3.6 referigerator runs for 20 sec then stops. Is there a reset sequence? I had it in my truck on a rough road, I was told to turn it upside down for a bit then try again?? New but bought last year.
As far as I know,you never lay a fridge down let alone turn it upside down. The oil for the compressor will drain into the coils & such & when you turn it on the compressor will burn out quickly. If you laid it down in the truck,let it sit upright for 24 hours or so,should be ok.
Jul 19, 2009 | Refrigerators
Gurrgeling noise after compressor kicks in
The sound that you are hearing is the refrigerant moving through the system. That can be a very normal sound. If you are not experiencing any other issues I think it is ok.
I can't believe that just sitting in a box can harm it. If it was stored in an upright condition, you should be fine. The system has oils in the compressor. So if it was stored upside down or something then the compressor could have run dry. This is usually ok if the unit returns to an upright position for a day or so before it is run.
Jul 03, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
384 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
