The hard drive does not appear on 'my computer'
    Sergeant:
  • 320 Answers
If it's not seen then:
1. Plugging wrong
2. Cable installed wrong or bad.
3. Bad drive.
4. Bad controller
Remove the cpu cover and check if the power cables and FRC cable is properly plugged in or not. also Check master/slave/CS jumper position. Try a different IDE cable. If your hard drive is in master then the other drive(cd-rom) should be in slave. If all the jumpers are removed then it means that slave. Try above steps. Hopefully it should work. Thank you.......
Posted on Sep 14, 2008
Need to transfer files from old computer to new Hitachi 3 terrabyte drive
The need to transfer files from one hard drive to another is common when restoring from backup, to make more room on a drive by archiving files or to copy or move files to a portable hard drive. Whether the destination drive is an installed second or third hard drive or is a portable hard drive, the procedure to transfer files from one hard drive to another remains the same.
Plug the destination hard drive into the computer if the drive is portable, and confirm that the computer has recognized the hard drive with a pop-up acknowledgment message. Click the "Start" button then click "Computer" or "My Computer," and then double-click on the icon of the hard drive that contains the files to be copied. When a window appears displaying the contents of the hard drive, navigate to the location of the files to be transferred. Click on each file to be transferred while holding down the "CTL" key to select all files to be copied. Right-click on one of the files that has been selected and click "Copy" in the menu that appears if you wish to leave a copy of the files on the hard drive, or click "Cut" in the menu that appears if you wish to move the files instead. Double-click on the icon of the destination hard drive in the "Computer" or "My Computer" window to display the contents of the hard drive in a new window. Navigate to the location on the hard drive where the files are to be saved. Double-click on the destination directory to open the directory and then right-click on blank space inside the directory window and click "Paste" on the menu that appears. A window will appear and display the status of the file transfer and disappear when the file transfer is completed. Hope this helps.
Jan 07, 2013 | Computers & Internet
I think my Hard drive has firmware problems or a virus, i connected it to my computer and it wouldnt appear on the list of hard drives and devices on "my computer" how do i resolve the problem?...
Check power connector of hard disc is in correct socket. Check if there is 5V and 12V in power connector.Try to replace SATA cable of your hard drive. If your hard drive is still not appear on your computer try to determine if your motherboard is already installed the sata software of your motherboard.
Jul 13, 2011 | Samsung Spinpoint F1 HD102UJ 1TB 7200 RPM...
How do I use your Verbatim? Please give me instructions
From Verbatim "Installing your portable hard drive is extremely simple - just use the included mini-USB cable to connect your hard drive to any free USB port on your computer. On Windows computers, a new icon will appear in My Computer representing your hard drive. On Mac OS systems, your hard drive will appear on the desktop as a new disk."
Jun 11, 2011 | Verbatim 320GB USB Portable Hard Drive
I have a WD 1TB Hard Drive. The HD shows up in 'safety remove hardware' but not in my computer. I have tried to assign a 'drive letter' to it in disk manager but disk manager is showing the hard drive to...
Try the following steps:
1. right click on my computer and select manage
2. choose Storage-> disk management.
If you say that the drive appears in the "safely remove hardware" than it should appear here too.
Select the hard drive and select "change drive letter and path". Add a drive letter and your hard drive
should appear in my computer.
Feb 11, 2011 | Western Digital WesternDigital Hard Drive...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
1tb external hard drive wont appear in my computer
Have you "Formatted" it before you used it, If NOT, Right Click on drive and select "Format" format NTFS. After this you should be able to use the drive as normal. Also Right Click, MY Computer, choose "Manage" when it comes up select Disk Management, and you can initialise it and format there.
Feb 28, 2010 | Buffalo Technology 1TB DriveStation...
My computer doesn't detect my Glyph hard drive.
Ok mac and oc have two different file systems There fat32 and i forget the refernce for mac they do not see each other But you can ge6t a driver and format the system so it will work to your benefites for get a software drive converter
Oct 18, 2009 | Computers & Internet
Fauly keyboard output can't type and there is constant letters appearing on screen without even typing. I have disconnected keyboard put usb keyboard in can type letters but the constant letters appearing...
Can you pull all data off of it? Is it still under warranty? If not find a computer on e-bay, pull the hard drive out of it and reinstall your hard drive in the new computer, buy an external 2 1/2 inch hard drive enclosure enclosure for the hard drive from the new computer. Thre is more than likey mother board problems.
Sep 20, 2009 | Acer Computers & Internet
Hard drive not recognised
It may not appear like your other drives eg. C: d: etc
it may appear as a removable drive lower down in the list.
Or you may have to add a drive letter
To add a drive letter in XP
Go to control panel, administrative tools, computer management.
Now select disk management, your drive should show in here
right click on it and click change drive letter and paths
now click add at the bottom of this box and just click ok
You should now be able to see it fine
Aug 24, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Rocstor external hard drive does not appear in my computer win xp although message it was installed when I connected the usb port
Good morning! first, make sure your external hard drive is properly connected to the USB port, then try to start / restart your computer again, automatically the computer should recognized the attached external HDD. best regards.
May 02, 2009 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
