Question about Microwave Ovens
When i plug it in, the light goes on and the turntable rotates. when I try to cook something, it says close the door when the door is already closed.
  • kalila09 Oct 26, 2008
    we just bought it a couple hours ago, we are going to return it but thought to see if any help was available. we plug it in, punch in time, close door, press start but it tells us to close the door. we found the switch that should be triggered when you close the door and were able to get it to start cooking twice but as soon as you open the door and close it, it will tell you to close the door when you try to cook.
5 Suggested Answers
  • 9098 Answers
SOURCE: Dacor Microwave - Light/Turntable turn on if we close the door
Sorry but I meant to also ask if it will still heat the food when you microwave with it.
I'll assume it does, but if not, please write back and let me know.
This would be a shorted relay RY1 on the control board.
There are two options for this model:
- You can order our exclusive modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
For details, see:
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. "Ed" Miller, AS-EET
Posted on Jan 19, 2009
  • 8909 Answers
SOURCE: Emerson Microwave Oven Model MWG9115SL: At
I suggest you check and/or replace the door interlock switches.
Hopr this helps.
Posted on Nov 07, 2010
SOURCE: Panasonic S943 microwave activates when
I had exactly the same problem with Panasonic NN-S962. I found very useful technical guide on the following website:
In the troubleshooting table on pages 31-32 it correctly states that this problem is caused by shorted primary switch. The technical guide has diagrams and photos helping with locating primary switch. I ordered a replacement switch from Sears PartsDirect (part no.46-692286-3). However, it is a common Omron switch V-15G-3C25 or its replacement with 16A analog sold by Sears PartsDirect that may be purchased cheaper elsewhere. After I replaced the switch my microwave started working normally. It was the easiest fix ever. Took me more time to research the problem and find the right part than actually fix it. That's why I decided to post this solution to save time for those who experience similar problems (looks like a fairly common problem for Panasonic microwave ovens).
Posted on Jan 29, 2011
  • 17130 Answers
SOURCE: model mh1160xsq-1 with the door closed and nothing
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean , solder and reset the board.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link:
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jul 14, 2011
Why does turntable rotate with door open?
The door switch could be stuck in the closed/on position. The electronic circuits could be malfunctioning. When the door is open, I sure hope than the microwaves cooking are not "ON". That could result in a very dangerous situation for you.
Dec 05, 2015 | Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
MY stop/clear button doesn't stop all the time.
It may be making noise, and the light comes on, and the turntable goes around, but I'll bet it's not actually cooking (although that CAN happen). Try putting a cup of water in the microwave when this happens and see if it gets warm. If it does NOT get warm, then you just have a bad door switch. If it DOES get warm, then you have a stuck relay on the control board, and the control board will have to be replaced.
Oct 15, 2014 | Microwave Ovens
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
My ge micro will not stop turning
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Sep 20, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
May 25, 2009 | Goldstar MV-1501 Microwave Oven
SANYO EM-D9550. Turntable turns when off but not when cooking.
That's sounds pretty strange!
Since I don't have any service data on Sanyos, I'd have to speculate.
I would guess that one scenario that could cause it would be if the turntable were turned off via the control panel, but there was a switch or switch mount problem.
I would refer you to their support people:
Dec 08, 2007 | Sanyo EM-D1100 1100 Watts Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
